251
OxygenOS 10.0.5 [EU and Global] and 10.3.2 [India] for the OnePlus 7 Pro and OnePlus 7
  1. Federico Prencipe
    Honeycomb Apr 4, 2020
    Federico Prencipe , Apr 4, 2020 :
    Yes of course, with OP is necessary.
    Also never forget that we use the phone and not viceversa so if you need the phone for your whole day there is no 20/80% rule or whatever, you need 100% charge and that's not always enought
  2. Darsh93
    Gingerbread Apr 4, 2020
  3. _mr.sonu__
    Cupcake Apr 4, 2020
  4. G_Sourav_Chakraborty_Xgt
  5. G_Sourav_Chakraborty_Xgt
  6. F1565333625018
    Cupcake Apr 4, 2020
    F1565333625018 , via OnePlus 7 , Apr 4, 2020 :
    problem in my oneplus device sometimes the mobile does not take rapid charging through OnePlus charger i have original charger and cable then too it's charging normally
  7. Indyjones89
    Eclair Apr 4, 2020
    Indyjones89 , Apr 4, 2020 :
    Good update Oneplus , i hope in a translation of my language(Italian) for the future updates and improvements of the Oxygen
  8. RomeoD
    X1568888095586 likes this.
  9. fahadleee
    fahadleee , via OnePlus 7 Pro , Apr 4, 2020 :
    very strange I received Google March security update and I did the update one week later I wiped my phone now it's on February update and when I try to search for update it says up to update
  10. fahadleee
  11. Samadgaur77
    Cupcake Apr 4, 2020
  12. xSniper
    Cupcake Apr 4, 2020
    xSniper , Apr 4, 2020 :
    hello guys, a big bug with 7 pro 5g is if you choose face unlock and you hold your camera to not pop-up your phone will unlock it will bypass pin asking or anything else. other bug is the fingerprint, i can unlock the phone with gloves in my hand :) is not 100% sure is gone work but in 75%of case's is unlocking. the wifi is not so stable, if you try to download at high speeds (trackers, popcorn time for example) your wifi will get stuck, you need to reset your wifi or to turn it off and on again. i hope my review will help you guys. if you have any solution for my problems im hear to listen.
  13. D1568634786675
    Cupcake Apr 4, 2020
    D1568634786675 , Apr 4, 2020 :
    I'm having one more problem.Wherever I try to enter hidden space it takes a lot of time to load and sometimes it hang. Plz fix it next time.
  14. xSniper
    Cupcake Apr 4, 2020
    yes i got it few days back. 10.0.5 EU
  15. bagufix
  16. xSniper
    Cupcake Apr 4, 2020
    tell me how and i can do it, why not.
  17. bagufix
  18. Tumio
    Tumio , via OnePlus 7 Pro , Apr 4, 2020 :
    Google files
  19. xSniper
    Cupcake Apr 4, 2020
