251
OxygenOS 10.0.5 [EU and Global] and 10.3.2 [India] for the OnePlus 7 Pro and OnePlus 7
  1. X1568888095586 and fanil like this.
  2. Swejuggalo
    Lollipop Apr 6, 2020
    Swejuggalo , via OnePlus 7 Pro , Apr 6, 2020 :
    Mostly EU lacking equalizer, never has call recording. Basically some EU regulations.
    X1568888095586 likes this.
  3. kmaier
    Honeycomb Apr 6, 2020
  4. kmaier
    kmaier , via OnePlus 7 , Apr 6, 2020 :
    thanks
  5. I1562869506998
    Gingerbread Apr 6, 2020
  6. SenTamizhan
    Eclair Apr 6, 2020
    SenTamizhan , Apr 6, 2020 :
    I am getting 8.30 hrs ost on my 7 pro. but I am in 9.5.3. so think well before post as no issue.
  7. SenTamizhan
    Eclair Apr 6, 2020
  8. pritamashwani
    fanil and Sagarshaikh like this.
  9. Nikhil_choudhary
    Eclair Apr 6, 2020
    V1560165685313, fanil and Sagarshaikh like this.
  10. SebastianKNT , via OnePlus 7 Mirror Red , Apr 6, 2020 :
    OnePlus 7 pro has bigger battery than 7 and that was first charge after update and before upgrade to android 10 was the same, so for me is no issue
  11. K1586187085932
    Cupcake Apr 6, 2020
  12. Luka_m125
    Froyo Apr 6, 2020
    Luka_m125 , Apr 6, 2020 :
    also bigger resolution, display size and refresh rate and the battery is just 'a little' larger.
    better battery life on the normal op 7 any day...
    SebastianKNT likes this.
  13. Jav P
    Jav P , via OnePlus 7 , Apr 6, 2020 :
    The notch issue is not a but, that's the way it is, going the Google way, and I doubt they will change it in the near future.
    I've always had a very good battery life so I can't help you with that, never seen any serious battery drain.
    You will need a full ROM for your device and from there go with incremental updates.
  14. Thomas_Shelby
    Cupcake Apr 6, 2020
    Thomas_Shelby , Apr 6, 2020 :
    This is after the update, for the app security the message displayed 'you still have 2 chances' still exists even after I have scanned 5 unsuccessful attempts.
    Is it only with my device or does the update needs a fix to a patch?
    gauravM007 likes this.
  15. gauravM007 , via OnePlus 7 Mirror Gray , Apr 6, 2020 :
    okay ...so notch disable option is not there ?
  16. Jav P
    Yes, it is, but not the same than the old way, The status bar icons will appear under the notch area when you hide it.
  17. Jav P
    It depends, many devices have already received the 10.0.5 update, including mine.
  18. Ujjwalprashar
    Ujjwalprashar , via OnePlus 7 , Apr 6, 2020 :
    Again it's been a week still no update. When you are already giving bi monthly updates on top of that the only feature of the update is a security patch you'd hope the rollout will be quick.....
