251
OxygenOS 10.0.5 [EU and Global] and 10.3.2 [India] for the OnePlus 7 Pro and OnePlus 7
  1. M1573823994579
    Cupcake Apr 9, 2020
    U1531132288045 likes this.
  2. Emmi777
    Gingerbread Apr 9, 2020
  3. Ciprian Flower
    Ciprian Flower , Apr 9, 2020 :
    tomorrow
  4. Luka_m125
    Froyo Apr 9, 2020
    Luka_m125 , Apr 9, 2020 :
    Massive lag when switching between apps.
    Please fix this in the next update because it's very laggy.
    Pratheekh Chandra likes this.
  5. JUNAID_GANDHI
    Froyo Apr 9, 2020
    JUNAID_GANDHI , via OnePlus 7 , Apr 9, 2020 :
    MAJOR HEAT ISSUE - OP7 [e]1f525[/e][e]1f525[/e][e]1f525[/e]
    After this OTA update I can't use my OP7 more than 10-15 minutes. It heats up too much that I can't hold it in my hand for long.
    Please fix this issue
  6. N1559969803250
    Cupcake Apr 9, 2020
  7. Aryan.sartha
    Eclair Apr 9, 2020
    Aryan.sartha , via OnePlus 7 Pro , Apr 9, 2020 :
    Today it's 9 April 2020 and you can see that my phone is having security patch of 1 January 2020. Even now phone se is showing it red now . One plus is cheating there customer . Trusting on this Chinese company was my fault. I don't know why I paid such a huge amount to one plus. Honor is having best camera , nokia is giving best security patch updates. What one plus is giving . They are simply selling there phones. Once phone is sold they forget about the customer. Very bad service by one.
  8. Swejuggalo
    Lollipop Apr 9, 2020
    Swejuggalo , via OnePlus 7 Pro , Apr 9, 2020 :
    I would investigate the battery stats. Heat usually comes for a reason and not by itself.
    By heat you mean what exactly? Do you get overheat warnings? What ambiant temperature? What do you do when it heats up?
  9. CHMP
    Cupcake Apr 9, 2020
    D1569795382529 likes this.
  10. jatin0990
    jatin0990 , via OnePlus 7 , Apr 9, 2020 :
    off krke charge kro ek bar
  11. JUNAID_GANDHI
    Froyo Apr 9, 2020
    No. I didn't get any overheat warning. Whenever my phone heats I just turn off net and keep it aside for few minutes.
  12. Swejuggalo
    An update with March is currently rolling out. It should be rather close for global rollout. Staged rollout is NORMAL.
    And if you wonder why no February... They update security bi-monthly. They even provide a schedule on how often they update.
    Normally it's 1 update per 1-2 months. And security normally only when bi-monthly accours.
  13. JUNAID_GANDHI
    Froyo Apr 9, 2020
    What will happen then? I change my phone once a day. I switch it off at night & turn it on in morning
  14. J1561403696375
    Donut Apr 9, 2020
    J1561403696375 , via OnePlus 7 , Apr 9, 2020 :
    OnePlus makes us April fool about the phone update available for oneplus 7 and 7pro I request all of you to wait for update and don't do it manually
  15. Aryan.sartha
    Eclair Apr 9, 2020
    it's 9th April my friend. Evry other companies already given there updates on 1st of the month . Tell me what's the benefits of paying huge amount to one plus if they this much slow
  16. Swejuggalo
    Ah. Check your battery stats and look for any abnormal drains. Something is probably draining extra much.
    You many need to wipe either cache or data on any troublesome apps. If you haven't done so yet try to charge to 100% and leave it connected for some time after it have reached 100%
  17. BeingIncog
    Nougat Apr 9, 2020
  18. JUNAID_GANDHI
    Froyo Apr 9, 2020
    Okay I'll charge it to 100%
    I had wipe catch before and after installation.
    Most of the time I don't change my phone 100%. I keep it between 15 - 80 %.
  19. Swejuggalo
    True. They are a little behind there. But how many offers closed and open betas developed side by side stable?
    OnePlus focus is clearly not monthly or early security updates.
  20. Aryan.sartha
    Eclair Apr 9, 2020
    what's more important brother . Getting other updates either security updates.
