90
OxygenOS 10.0.5 for OnePlus 7T Pro [10.3.0 in India]
  1. Aman.Bhardwaj
    Froyo Dec 16, 2019
    Aman.Bhardwaj , Dec 16, 2019 :
    no dude.. its not rolled for every one. u r lucky. we are not. we have been checking but its not coming.
  2. Sudhanshu Balodhi
    Gingerbread Dec 16, 2019
    Sudhanshu Balodhi , Dec 16, 2019 :
    I think it's roll out mate 'cuz my friend are also getting A10. Don't worry you will get it soon. Support☮️
  3. Aman.Bhardwaj
    Froyo Dec 16, 2019
    hope so. thanks
  4. Profound Bandit
    Cupcake Dec 16, 2019
    Profound Bandit , Dec 16, 2019 :
    I haven't gotten it either. I don't know what is going on.
    Txtsuo likes this.
  5. Chmiel0ne
    Donut Dec 16, 2019
    Chmiel0ne , via OnePlus 7T Pro , Dec 16, 2019 :
    is your phone branded? (like tmobile)
    also try google play app like oxygenos updater
    GKhushal likes this.
  6. deep0611
  7. Hank Hung
  8. Profound Bandit
    I have an unlocked one I purchased directly from OnePlus. I'll look at the app.
    Txtsuo likes this.
  9. dan_0272 , via OnePlus 7T Pro McLaren Edition , Dec 16, 2019 :
    Received the update yesterday as 10.3.0...
    Come on OnePlus why this confusion with repeated discrepancies regarding the Oxygen OS version which started with as I remember with the OnePlus 6t onwards...
    The community app shows different OS version while the one which we get installed shows different....
    Or if the different versions are based on region based then you should specify 1st in a post....
    ¯\_ಠ_ಠ_/¯
  10. Tymcio
    Froyo Dec 16, 2019
    Tymcio , Dec 16, 2019 :
    install oxygen updater and share ZIP [e]1f60a[/e]
  11. danvxz
    Honeycomb Dec 16, 2019
  12. SkypirateDE
    Donut Dec 16, 2019
  13. zhaogeorge3
    Jelly Bean Dec 16, 2019
    Txtsuo likes this.
  14. Abhilash_PM
    Froyo Dec 16, 2019
    Abhilash_PM , Dec 16, 2019 :
    Hi OnePlus Team. I am wondering why create so much of confusion with different version numbers for India and Global roms? India region is getting OTA update for OP7T Pro with version 10.3.0 where as EU and other regions are getting it as 10.0.5. Would really like to understand the objective behind it. I also noticed that OP7T also received 10.3.0 in India. I am wondering if there is a merge happening for roms of OP7T and OP7T Pro having unified versioning system? Well just a guess
  15. dan_0272 , via OnePlus 7T Pro McLaren Edition , Dec 16, 2019 :
    I also have the same question...
    They are continuously repeating the same mistake in their upcoming updates which is just a minor one which is not expected from a company like OnePlus having such great software implementations.....
    & if there is some unification regarding regions OnePlus must tell us through a separate post....
    infinity.erdem likes this.
  16. danvxz
    danvxz , via OnePlus 7T Pro , Dec 16, 2019 :
    it's not really different versions numbers. all of 7T Pro should be at 10.0.5. OnePlus just have messed up the version numbers... I have no idea where they for 10.3.0 from.
    F_Miguel_Sá_tIZO likes this.
  17. Abhilash_PM
    Froyo Dec 16, 2019
    Some cosmetic glitches I found after an update to 10.3.0 on my OP7T Pro McLaren:
    1. The new menu option in the settings screen is not adhering to the McLaren Theme on McLaren devices. The icons and titles are blue instead of papaya orange
    2. I've started to notice that while opening OnePlus Care app, the top status bar icons are still in white color which blends with the foreground of the app making it almost impossible to read. This behavior is also noticed on some other apps (such as Airtel Thanks App) where the top status bar does not automatically correct colors. I am not sure if this is already there but I'd love to have an intelligent system coded for status bar to adapt to colors on the foreground app and adjust itself to have optimal visibility.
  18. Sandchait
    Eclair Dec 16, 2019
    Sandchait , Dec 16, 2019 :
    no one is replying in OP6 device thread. that's why he is asking here. also there is no update from any OP developers even after 15 days. Pathetic by OP team. At least they have to reply what's going on. if global roll out has been kept in hold or anything else.
    #38
    Y1548889410117 and MaD_RaT like this.
  19. dan_0272
    Froyo Dec 16, 2019
    dan_0272 , Dec 16, 2019 :
    Same here
    My 7t Pro McLaren is also having these issues and the blending of white colour status bar icons with the foreground of apps is seen in a major of my apps sometimes even in Google apps....
    #39
  20. Mayur Awate
    Donut Dec 16, 2019
    Mayur Awate , Dec 16, 2019 :
    guyz ... my charging speed reduced from 5880 mA to 2840mA after 30% charge ....
    whqt is issue
    after 10.0.4 update
    #40
    M1577978524635 likes this.
