90
OxygenOS 10.0.5 for OnePlus 7T Pro [10.3.0 in India]
  1. P1571415541710
    Cupcake Jan 16, 2020
  2. Fixxer
    Gingerbread Jan 16, 2020
    Fixxer , via OnePlus 7T Pro , Jan 16, 2020 :
    Samsung has already started pushing January security patch updates for it's older phones like s9 and s8 and we are still stuck on OnePlus flagship with November update.
    Back when I had the OnePlus 5t and 6, I remember that the updates were delivered timely.
    What happened meantime?
  3. M1577257315678
    Donut Jan 16, 2020
    M1577257315678 , Jan 16, 2020 :
    I had got it
    In India ,WiFi calling is available only in Airtel sim
  4. OIC71
    Eclair Jan 16, 2020
    OIC71 , Jan 16, 2020 :
    Are you sure it's also available and supported by your carrier? It isn't enough that your device supports WiFi calling/VolTe, if your carrier doesn't.
  5. snabb
    Honeycomb Jan 16, 2020
    snabb , via OnePlus 7T Pro , Jan 16, 2020 :
    I can sure you with 110% that the update process will not go faster just because you or someone else writing comments like that.
    The update will be released soon.
    Patience.
    ngydat likes this.
  6. Fixxer
    snabb
    Patience.​
    Was I intending to do that? Read my comment.
    I was just wondering what happened in the last around 12 months when I haven't been using an OnePlus phone.
    I can assure you also that your kind of reply has no added value whatsoever.
    And if I have suggestions or complaints, I'm writing to OnePlus directly through their feedback tool, not complaining on the forum...
    donaldvc likes this.
  7. snabb
    Well, your comment "added" a lot of value.
    Keep doing the same way.[e]1f601[/e]
    ngydat likes this.
  8. Fixxer
    It was just a reply to you.
    No need to add value on that
  9. ngydat
    KitKat Jan 16, 2020
    ngydat , Jan 16, 2020 :
    The problem is you can ask all you want but since it's a users' forum, you won't have an answer.
    snabb likes this.
  10. Fixxer
    ngydat
    The problem is you can ask all you want but since it's a users' forum, you won't have an answer.​
    I was thinking maybe they made an announcement, that only perhaps the beta software will have the latest security patches or they need more time for testing, or something like that (that I missed meantime when not using an OnePlus phone and no longer checking forums).
  11. ngydat
    KitKat Jan 16, 2020
    Usually that's the case even though I personally think that we don't need oxygenos updates to update the security patch.
    snabb and Fixxer like this.
  12. KathiravanJLR
    Gingerbread Jan 17, 2020
    KathiravanJLR , via OnePlus 7T , Jan 17, 2020 :
    high end phones heat up during intense tasks like gaming,rendering,benchmarking etc..it's normal
  13. A1576432999685
    Cupcake Jan 17, 2020
  14. iamghouri
    Froyo Jan 18, 2020
    iamghouri , Jan 18, 2020 :
    when i click nightscap on front cam than camera rotate automatically to rear camera
    anyone having this issue ?
  15. Darius22574
    Froyo Jan 18, 2020
    Darius22574 , via OnePlus 7T Pro , Jan 18, 2020 :
    That's how it should be, if you want to take photos in the night with the front camera you can try GCam.
  16. M1577978524635
    Cupcake Jan 18, 2020
    M1577978524635 , Jan 18, 2020 :
    After this upadate my mobile got slow and battery drains too fast.and the major bug is while swiping upwards for opening app menu its show fully black screen.it doesn't get to normal screen untill we switch off the phone..i have been facing this problem since i bought a phone.is this software bug or device problem
  17. iamghouri
    Froyo Jan 18, 2020
    Can nightscape photos be taken via front camera?
    Please check and advise if this is a bug.
  18. Darius22574
    Froyo Jan 18, 2020
    FisherXDA likes this.
  19. bipuwam
    Eclair Jan 18, 2020
    bipuwam , Jan 18, 2020 :
    use updater app
  20. Q1576469658160
    Donut Jan 19, 2020
    Q1576469658160 , Jan 19, 2020 :
    I tried the app but had an issue whenever I tried to update. I ended up using a VPN to the Netherlands to download the update
