184
OxygenOS 10.0.6 [EU and Global] and 10.3.3 [India] for the OnePlus 7 Pro and OnePlus 7
  1. kmaier
    Honeycomb Jun 1, 2020
    kmaier , via OnePlus 7 , Jun 1, 2020 :
    sarahmic
    Update is ok till now but for Battery one has to at least charge the phone for 3/4 times and then the mobile will settle.
    It's then that we can see if battery is better or worse.
    I can't understand people who got the update yesterday saying the battery is worse - you can't say that before you leave the phone settle.​
    I am on 7 hours, 15 minutes with 18 percent battery left. that is with one day on this update, before it's really settled. so for me it's pretty good. I cleared the cache, that's it.
    A lot depends, of course, if yourl are on wifi most of the time (better battery life) or have a strong cell signal ( also good battery life). if you are on the cell connection most of the time and the reception isn't very good, then the battery life will suffer.
  2. kmaier
    use oxygen updater. takes 15 minutes depending on your connection. it's safe. I have used it at least 20 times (including on son's and wife's OnePlus 6's.)
  3. Ghanishtk
    Eclair Jun 1, 2020
  4. kmaier
    your can find on the web. I do it but not sure it helps.
    Power off your device.
    Once shut down, press and hold Volume down and power key simultaneously until you see OnePlus and Android logo.
    Release the keys.
    Now select your preferred language.
    Tap on “Wipe Data and cache”.
    Then select “Wipe cache”.
    Give your consent to wipe cache by tapping on “Yes”.
    Now reboot your device.
    All the cache data will be cleared now.
  5. Artemus.
    Nougat Jun 1, 2020
    Artemus. , Jun 1, 2020 :
    This does nothing... a placebo effect.
    Georgeoneplus7pro likes this.
  6. G_Ziyad_Cheema_UriC likes this.
  7. kmaier
  8. Artemus.
    Nougat Jun 1, 2020
    When is the last time you formatted?
  9. Attached Files:
  10. Swejuggalo
    Lollipop Jun 1, 2020
    Swejuggalo , via OnePlus 7 Pro , Jun 1, 2020 :
    Do you hide navigation bar? Tried it with showing the bar?
    Bobby_Rivera likes this.
  11. Luigiformentini
    Donut Jun 2, 2020
    Luigiformentini , Jun 2, 2020 :
    i know what they are for, but it wasn't there before and it's a stupid position to have those bottons that i dont even use and it's annoying ( I know for a fact that in samsung devices we can hide that back bar and icons ... but oneplus doesnt have that option )
  12. Artemus.
    Nougat Jun 2, 2020
    Artemus. , Jun 2, 2020 :
    It's Gboard.
  13. Luigiformentini , via OnePlus 7 Pro , Jun 2, 2020 :
    Yeah you're right, I disabled all other input methods and the keyboard selector vanished... But the arrow to being it down it is still there 😕
    Biba Munda likes this.
  14. Artemus.
    Nougat Jun 2, 2020
    Weird, mine doesn't have this.
  15. Luigiformentini , via OnePlus 7 Pro , Jun 2, 2020 :
    I'm using SwiftKey keyboard, it usually doesn't have anything there... After the update that f* arrow showed up there
  16. laikexpert
    Gingerbread Jun 2, 2020
    laikexpert , Jun 2, 2020 :
    Settings
    Buttons & gestures
    Navigation bar & gestures
    CHOOSE NAVIGATION BAR
    Examples:
    1.) Navigation gestures, (arrow bellow keyboard) is to turn off the keyboard.
    2.) Back, Home, recents, (arrow bellow keyboard) does not exist at all.
    P.S.
    In addition, on my phone
    I use Gboard keyboard & Nova Launcher.
    Biba Munda and Luigiformentini like this.
  17. RealSirMorokei , via OnePlus 7 Mirror Gray , Jun 2, 2020 :
    Battery update. Second full charge after update.
    Mobile data off, wifi on, Bluetooth on and connect, sync on, auto brightness on.
    Background apps: DNS66, WhatsApp, Mi Fit, Google one/photos, Crono, DarkQ
  18. deeneshraz
    Donut Jun 2, 2020
    deeneshraz , via OnePlus 7 , Jun 2, 2020 :
    new update new bugs. mobile heating issue has raised.
    I dint any find any optimization in battery. why don't you give us a pocket mode in the next update.
