129
OxygenOS 10.0.7 [EU] and 10.3.4 [India & Global] for the OnePlus 7 Pro and OnePlus 7
  1. Asish Behera
    Honeycomb Aug 4, 2020
  2. Godfather 1
    Jelly Bean Aug 4, 2020
    Godfather 1 , via OnePlus 6 , Aug 4, 2020 :
    Or maybe one update across devices at the same time...like some other folks do...and keep hardware the only difference between flagships and mid range phones... OnePlus is known for its software...
    asopat, Ajdi, mahekparmar and 2 others like this.
  3. Shiva_Rohith
    Gingerbread Aug 4, 2020
  4. Alsteree
    Eclair Aug 4, 2020
  5. Gav_W86
    Starting Point Expert Community Expert Aug 4, 2020
    Gav_W86 , Aug 4, 2020 :
    as it says in the opening post of the thread:
    This OTA will have a staged rollout. The OTA will be received by a limited number of users today and will have a broader rollout in a few days after making sure there are no critical bugs. Using VPN to download this build might not work as the rollout Is not based on regions and is randomly pushed out to a limited number of devices.
  6. Alsteree , via OnePlus 7 Pro Almond , Aug 4, 2020 :
    Sorry, I didn't read the whole post.
  7. Z1539282623808
    Eclair Aug 4, 2020
  8. Rishi_Pisces
    Froyo Aug 4, 2020
    ranith1995 and Rmz_._ like this.
  9. udayJR
    Froyo Aug 4, 2020
  10. Yunusrg
    Froyo Aug 4, 2020
    A1572776150617 and DEVGHOST10 like this.
  11. Adwaith07
    Eclair Aug 4, 2020
  12. ayala_aditya
    Donut Aug 4, 2020
    ayala_aditya , via OnePlus 7 , Aug 4, 2020 :
    They wantedly removed notch as the other devices are with full screen #oneplus
    I droped the same to the developer team until now i didnt get any update of it!
    Swapnil4776 and Ajay_Bhatt like this.
  13. Tedinetto
  14. H1572770740818
    Donut Aug 4, 2020
    Csevege, SUB@ZERO and Ajdi like this.
  15. c3drik67
    c3drik67 , Aug 4, 2020 :
    50/50 maybe yes, maybe no
    pablofg1978 and Tedinetto like this.
  16. laikexpert
    laikexpert , Aug 4, 2020 :
    Local upgrade OnePlus 7 Pro
    1.) Download zip file 10.3.4.GM21AA (Global+India) 2.1 GB from Official server
    and copy it to the root of the internal memory
    (i.e., not in a folder such as Downloads, for example).
    2.) Go to Settings> System> System Updates> Click the gear at the top right>
    Local Upgrade> Click on the appropriate installation package> Update
    3.) After the update is completed, click Restart
    4.) The update was successful.
    Note If you do not see the firmware file,
    then check the file extension should be .zip
    (if you have .zip.jar just rename it by deleting .jar)
    P.S.
    Or download and install 10.3.4 (Global)
    through Oxygen Updater app (Play Store)
    Tedinetto likes this.
  17. runforfun
  18. pant_psi13
    Froyo Aug 4, 2020
    #38
  19. sunand777
    #39
  20. Gio567full
    Ice Cream Sandwich Aug 4, 2020
    Gio567full , Aug 4, 2020 :
    Turn off ram booster
    #40
    TefkrosTheAviator likes this.
