129
OxygenOS 10.0.7 [EU] and 10.3.4 [India & Global] for the OnePlus 7 Pro and OnePlus 7
  1. ncoolnn
    Cupcake Aug 10, 2020
    ncoolnn , Aug 10, 2020 :
    I am struggling with Bluetooth connection to my headphones or air pods after the new update. Anyone else facing this issue or is it just me? Can someone suggest a solution??
    RAHIL_GOSWAMI and V1597065423537 like this.
  2. 1bhavin12001
    Gingerbread Aug 10, 2020
  3. Z1570266934951
    Eclair Aug 10, 2020
    G_Nekozwartz_XD_YmBx likes this.
  4. Artemus.
    Community Hero 2020 Aug 10, 2020
    Artemus. , Aug 10, 2020 :
    No. Unless it has "5G" in the name it will not.
  5. R@hul3660
    R@hul3660 , Aug 10, 2020 :
    whenever I'm trying to call using bluetooth bullets wireless z the connection automatically turned to phone (bluetooth-phone)
    bluetooth connection automatically getting disconnected
    please check and while call is going on smoothly but sim card signal shows no range
  6. R@hul3660
    yes I'm also facing issue
  7. R@hul3660
    there too much voice drop issue in bluetooth call please do something we r working from home facing too much issue
    is someone also facing same problem
    RAHIL_GOSWAMI likes this.
  8. c3drik67
    Honeycomb Aug 10, 2020
    c3drik67 , Aug 10, 2020 :
    only oneplus 7 pro 5g version
  9. Shalin05
  10. akks
    KitKat Aug 10, 2020
    akks , Aug 10, 2020 :
    I've no heating issues. Not sure what's the problem at your end
  11. akks
    KitKat Aug 10, 2020
    Last charging 10 hours back, I would consider it really bad battery life. SoT can be even 12 hours if you keep reading a book in Adobe reader for 12 hours.
  12. Ankush__Chauhan
    Eclair Aug 10, 2020
    chetan_patel likes this.
  13. MadyKarthi
    chetan_patel and Alsteree like this.
  14. SHP@7PRO
    Eclair Aug 10, 2020
  15. Fivefoothulk
    Fivefoothulk , via OnePlus 7 , Aug 10, 2020 :
    Hi,
    Ever since the new update, I've been having issues with the audio on my OnePlus 7. The volume is significantly lower and when connected to Bluetooth headset, it says connected but the audio output is still from the phone's speakers.
    I have tried disconnecting and reconnecting my bluetooth device and resetting the bluetooth settings on my phone.
    Please help.
    neeraj_8055 likes this.
  16. sutanshu
    sutanshu , Aug 10, 2020 :
    After long time now getting good battery backup almost 8hr+ on full hd & 6hr+ qhd :O
    SpartanVissepo likes this.
  17. lakhotiakunal
    lakhotiakunal , via OnePlus 7 , Aug 10, 2020 :
    Thanks for this update. It's was second today after updating my phone OnePlus 7 and it's been 24 hours since last charge and I still have 34% of juice left after medium usage, which earlier used to last just about 25 hours on similar usage. Great job on battery this time guys, thanx a ton!!
  18. RishinP
    Froyo Aug 10, 2020
    RishinP , Aug 10, 2020 :
    using OnePlus 7 and on 10.3.4, when using YouTube, sometimes the icons in the status bar are not showing, I have to swipe from top to see them and it automatically again disappears again in a second. is this a new YouTube thing or a bug?
    any one else noticed or faced this ?
