129
OxygenOS 10.0.7 [EU] and 10.3.4 [India & Global] for the OnePlus 7 Pro and OnePlus 7
  1. RishinP
    Froyo Aug 10, 2020
    RishinP , Aug 10, 2020 :
    I faced this issue once, but a restart solved this problem. so please restart your phone once and try again.
  2. Satrajit Chakraborty
    Gingerbread Aug 10, 2020
  3. Midhu m
    Cupcake Aug 10, 2020
    Midhu m , via OnePlus 7 , Aug 10, 2020 :
    Anybody have problem with alert slider,I only noticed after updating that the phone is not changing to ring mode using slider,rest two modes are working,
  4. Artemus.
    Nougat Aug 10, 2020
    Artemus. , Aug 10, 2020 :
    Clean it.
  5. laikexpert
    Honeycomb Aug 10, 2020
    laikexpert , Aug 10, 2020 :
    Local upgrade OnePlus 7 Pro
    1.) Download zip file 10.3.4.GM21AA (Global+India) 2.1 GB from Official server
    and copy it to the root of the internal memory
    (i.e., not in a folder such as Downloads, for example).
    2.) Go to Settings> System> System Updates> Click the gear at the top right>
    Local Upgrade> Click on the appropriate installation package> Update
    3.) After the update is completed, click Restart
    4.) The update was successful.
    Note If you do not see the firmware file,
    then check the file extension should be .zip
    (if you have .zip.jar just rename it by deleting .jar)
    1.) Download zip file 10.3.4 (Global+India) 2.1 GB from Official server
    P.S.
    Or download and install 10.3.4 (Global)
    through Oxygen Updater app (Play Store)
    G_Xia_Min_De_QjdK and Swejuggalo like this.
  6. G_Xia_Min_De_QjdK , via OnePlus 7 Pro , Aug 10, 2020 :
    Thank you so much for reply and explain .
    One last question , is there anything that should be done before or after the update such as wipe cache or so to avoid any issues with the update ??
  7. Spyrek
    Spyrek , Aug 10, 2020 :
    Anyone having gps issues? Apps show info that google location services are disabled...
    Clearing location services cache, disabling/enabling google location services didn't help.
  8. Swejuggalo , via OnePlus 8 Pro Ultramarine Blue , Aug 10, 2020 :
    Many apps or even all of them? Maybe some app preferences got wrong and thus blocking something that needs to be on.
    So just to be sure you could try to reset them.
  9. Spyrek
    All of them, only fake gps location is working(fakegps app).
  10. UnicornZ
    Ice Cream Sandwich Aug 11, 2020
    UnicornZ , via OnePlus 7 Pro , Aug 11, 2020 :
    Are you using any third party launcher
  11. F1577261221395
    Cupcake Aug 11, 2020
    F1577261221395 , Aug 11, 2020 :
    mine was good but stop working after update
  12. bcharles99
    Gingerbread Aug 11, 2020
  13. bcharles99
    bcharles99 , via OnePlus 7 Pro , Aug 11, 2020 :
    Same here...I think it created like that...but not sure it's a bug or not
    Gdsingh94 likes this.
  14. Swapnil4776
    Swapnil4776 , via OnePlus 7 , Aug 11, 2020 :
    Yes. Single tap screen wake still not working in some cases on my OP 7. When you leave your phone for long and try to wake the screen it doesn't work.(specially in the morning)
  15. Swapnil4776
    Single tap wake not working when i leave it for long without touching.
  16. RishinP
    Froyo Aug 11, 2020
    RishinP , Aug 11, 2020 :
    no, using our OnePlus launcher only
  17. rinkimekari
