129
OxygenOS 10.0.7 [EU] and 10.3.4 [India & Global] for the OnePlus 7 Pro and OnePlus 7
  1. F1582637483409
    Cupcake Aug 12, 2020
    F1582637483409 , via OnePlus 7 Pro , Aug 12, 2020 :
    I am using two profiles i.e personal and work profile. Post updation i cannot use google meet app in work profile, it is getting crashed whlie trying to join some meeting.
    However Meet app in personal profile is working fine. Please fix this issue.
  2. JohnTex
    Froyo Aug 12, 2020
    JohnTex , Aug 12, 2020 :
    So have to say, because credits to credits do. After wiping the cache this new update it's a good one.
    No major bugs notice.
    Photos also Portrait mode algorithms are working good again. ( before the cache wipe, I notice some lack of sharpness but the wipe worked for me, the sharpeness came back.)
    Let's hope that the next update will be a android 11, and better to came late and good, that another not stable update.
    This one for me, it's looking Stable, finally. I prefer a late update to a buggy one.
    kmaier, laikexpert and Asish Behera like this.
  3. Asish Behera
    Honeycomb Aug 12, 2020
    Asish Behera , via OnePlus 7 , Aug 12, 2020 :
    Probably not. Because OB 17 has been released and there is no android 11 in it.
  4. Govindkumar991
    Eclair Aug 12, 2020
    chetan_patel and Sahil_lihas like this.
  5. ravish5497
  6. akks
    KitKat Aug 12, 2020
    akks , Aug 12, 2020 :
    No, it's there for me
  7. Sahil_lihas
  8. bcharles99
    Gingerbread Aug 12, 2020
    bcharles99 , via OnePlus 7 Pro , Aug 12, 2020 :
    Just lock your phone then unlock the phone with pattern/password (because finger print scanner is in disabled state ).then go to hidden space you can see finger print scanner
  9. JohnTex
    Froyo Aug 12, 2020
    Really hope that if it's not the Android 11 , that they don't had nothing special, just minor fixes, and some buds software improvements and leave the big changes to Android 11.
    I want a smooth android until 11 and not a bugged one like the last update before this one.
    Asish Behera likes this.
  10. B1566452576132
    B1566452576132 , via OnePlus 7 , Aug 12, 2020 :
    Finally happy to get a fix for tao to wake bug, but sadly some of camera features are compromised...i noticed nightscape mages are reddish sometimes. Earlier it was just awesome. oneplus please look into this. I don't know if i am the only one noticing this chang.
  11. Z1597257986411
    Deactivated User likes this.
  12. Payal_Riya
  13. Swejuggalo , via OnePlus 8 Pro Ultramarine Blue , Aug 12, 2020 :
    This usually is the result of something that has gone nuts. If you look in you battery stats do you see anything using a strange amount of battery? For example WhatsApp at 25% or similar?
  14. Payal_Riya
    Payal_Riya , via OnePlus 7 Pro , Aug 12, 2020 :
    No, none of my apps uses more than 10% battery but after this update only am suddenly facing this heating issue and drastically drain of my battery.
  15. Swejuggalo , via OnePlus 8 Pro Ultramarine Blue , Aug 12, 2020 :
    Nothing strange in full device usage either? Could have a higher Android System the first day or 2 though
  16. chetan_patel
    Eclair Aug 13, 2020
  17. zaveed
    Donut Aug 13, 2020
    zaveed , Aug 13, 2020 :
    I have the same issue and there are more users who are reporting. Google meet on work profile does not work. Have also raised a bug , yet to hear back from them.
  18. E1577426921521
    Cupcake Aug 13, 2020
    E1577426921521 , Aug 13, 2020 :
    Hi All,
    After this update my batery is draining upto 20% in idle mode also. Kindly suggest some solution please.
    Regards,
    Bala
  19. akks
    KitKat Aug 13, 2020
    akks , Aug 13, 2020 :
    We can't suggest you anything without seeing your battery stats. Check what's draining your battery when idle
  20. UnicornZ
    Ice Cream Sandwich Aug 13, 2020
