129
OxygenOS 10.0.7 [EU] and 10.3.4 [India & Global] for the OnePlus 7 Pro and OnePlus 7
  1. Suraj gurav 007
    Ice Cream Sandwich Aug 14, 2020
  2. PsychoPlayer
    Cupcake Aug 14, 2020
    PsychoPlayer , via OnePlus 7 , Aug 14, 2020 :
    Getting high ping in pubg after this update (while using mobile data of jio) but the speed is ok. Tried factory reset but still the problem is there.
  3. S1570107518954
    S1570107518954 , Aug 14, 2020 :
    why the power key is not working in my phone after update... after pressing it to switch off it automatically open the google assistant
  4. PauloCoelho8
    Eclair Aug 14, 2020
    PauloCoelho8 , via OnePlus 7 , Aug 14, 2020 :
    I got WiFi connection issues as well
  5. Zex85
    Froyo Aug 14, 2020
    Zex85 , via OnePlus 7 , Aug 14, 2020 :
    This threads are made just to let users share with community the bugs that they're facing in each and every update but OnePlus won't know the issue you're facing unless you submit a bug report with the log file attached
    So please (fix it)" comments "won't help you nor help us
  6. beta3d10
    beta3d10 , via OnePlus 7 , Aug 14, 2020 :
    A hell lot of Network Issue after the last update .( India user.)After disconnecting a call network (Vodafone)getting vanish every time.Please work on it.This is affecting the whole view on One Plus.
  7. beta3d10
    same for me. ( Network-Vodafone)
  8. Abhik.b02
    Froyo Aug 14, 2020
    Abhik.b02 , Aug 14, 2020 :
    This sounds weird, but on the OP7, does anyone face long pause before the settings menu opens? This never happened before and can't be reproduced every single time! It's like once or twice when the settings is opened, either from notification shade or app tray. That's certainly not the end of the world, but just checking my digital wellbeing throught the day and facing this long pause (4-5 sec) before the app loads bugs me sometimes. Again, this happens only if the app is launched say after 4-5 hrs. (Haven't timed it). It stays in the memory after that and it launches in a second.
    This is the only app that takes time to load. Even the gallery app with tons of RAW files from my camera opens in a giffy! Not sure to what may be causing this...
    Kashishakul and bcharles99 like this.
  9. bcharles99
    Gingerbread Aug 14, 2020
    bcharles99 , via OnePlus 7 Pro , Aug 14, 2020 :
    You are absolutely right...I faced the same problem earlier build and this build...
    Kashishakul and Abhik.b02 like this.
  10. smile20
    smile20 , Aug 14, 2020 :
    I have to say im suprised. My first try with OxygenOs 10.0.1 was terrible, i mean battery life. I switched back to 9.5.8 and after months decided to try once again with 10.0.7. I have made clean install( wiped 9.5.8, updated to 10.0.7 and once again wiped) What can i say, everything so far works perfect, not even single problem. I knew that battery drain was fixed, but i thought that Oxygen 10 consume more battery than Oxygen 9. I was wrong! Everyones says it needs few cycles for battery to work longer, I share my battery statistics with FIRST cycle. 40h usage 100%>8%, 7h24m SOT, for me its more than i thought. I used phone normally, auto brightness, 1 day wifi, 2 day more LTE, bluetooth on, connected with my smartband, gps off. Alot Opera/Facebook, and playing game. If I could waited till 0/1% it would be 8h SOT. If you are concerned like I was before updating from Oxygen 9 to 10, dont be! If I have any problems with next days/weeks I'll post it here, so far no problems.
    [​IMG] [​IMG]
  11. Abhik.b02
    Froyo Aug 14, 2020
    Hmm, so its not the only case.
    Anyway, I'm still not able to isolate the reason for this. Maybe it takes this time to fetch the profile (the first row in settings app) details. Red cable club details for OnePlus account. Maybe, internet connection is poor at the same instant I hit settings and it takes time to get the details, and preloads the same after that. I don't know. It's something I noticed and wanted to share and get some insights...
    bcharles99 likes this.
  12. akks
    KitKat Aug 14, 2020
    akks , Aug 14, 2020 :
    Why don't you post in the concerned 10.3.4 thread instead of creating redundant threads?
  13. rpkkiran
    Froyo Aug 14, 2020
    rpkkiran , via OnePlus 7 Pro , Aug 14, 2020 :
    Shalin235
    Guys this is lit!!!!!! Yipeee
    Someone on youtube just posted a video of Oxygen OS 11 features that even works on all earlier phones with Android Oxygen OS 10 support.
    I installed oneplus gallery on 7 pro.
    Link of drive:- https://drive.google.com/drive/u/0/mobile/folders/1-3n3Bv2HYeBRvpfQJcMy6Vd6UgDUX9UB?usp=sharing
    Youtube Video:-​
    weirdly the launcher didnt seem to work properly. lemme knoe if it does work fine for y'all
    Kelcso likes this.
  14. rpkkiran
    Froyo Aug 14, 2020
    Something which i found out so far, the palm rejection in this update is screwed up. Getting much too many false touches on the sides. Anyone else experience this?
  15. Cervantes
    Lollipop Moderator Aug 14, 2020
    Cervantes , Aug 14, 2020 :
    Hi
    Please, check and use the latest update for questions and comments, Read the first post
    Use the search engine before opening a new thread
    Thread merged
    puma95 likes this.
  16. Kelcso , via OnePlus 7 Pro Mirror Gray , Aug 14, 2020 :
    Thx Bro,
    Notes
    Gallery
    Weather
    Widget it's very good :)
    rpkkiran likes this.
  17. rpkkiran
    Froyo Aug 14, 2020
  18. rpkkiran likes this.
  19. rpkkiran
    Froyo Aug 14, 2020
    Ah yeah, I've installed from apkmirror only,
    Launcher also works great after restart. Only the contacts app doesn't show any difference whatsoever
  20. Kelcso , via OnePlus 7 Pro Mirror Gray , Aug 14, 2020 :
    In Launcher whats the difference?? Im not try it. Yet.
