125
OxygenOS 10.0.7 [EU] and 10.3.4 [India & Global] for the OnePlus 7 Pro and OnePlus 7
  1. Armin2208
    Eclair Aug 4, 2020
    Armin2208 , Aug 4, 2020 :
    optimized charging is a critical feature. It needs to really work (otherwise it would "harm" batteries a little bit) and it contains much much code that couldn't work as expected.
    Watch faces on the other hand are simple. Not critical, a small amount of code and not much stuff to test.
    Hemanth4364 likes this.
  2. Yash Narain
    Gingerbread Aug 4, 2020
  3. c3drik67
    Honeycomb Aug 4, 2020
    c3drik67 , Aug 4, 2020 :
    you ask if new clock and optimized charge is not available in stable build.
    than new clock faces.. still not available yet for Stable build?
    My answer is yes is it in changelog for the clock. I have read correctly....
  4. Sagarshaikh
    Froyo Aug 4, 2020
    GAOBILINA likes this.
  5. baggz143
    baggz143 , via OnePlus 7 Pro , Aug 4, 2020 :
    Thank you. Exactly what I want and meant with my post.
  6. cyrillic
    Cupcake Aug 4, 2020
    cyrillic , via OnePlus 7 Pro Almond , Aug 4, 2020 :
    Updated to 10.3.4 today. So, some issues was fixed, but, this "hide keyboard button" can't be disabled. Also, "text" clock style is only in English language. My main language is Russian, but this clock style doesn't changed to Russian.
    Also, I see some freezes when Google keyboard appears at screen.
  7. C1587352310498
    Cupcake Aug 4, 2020
    C1587352310498 , via OnePlus 7 , Aug 4, 2020 :
    Dears
    1. When would we get the most expected OOS 11 for our OnePlus 7?
    2. We had received 10.3.4 for our OP7, on the contrary OP6 had been received 10.3.5. My question is why is this variation?
    Thanks
  8. c3drik67
    for the 2 , not same phone, not same firmware
  9. anupmehra
    anupmehra , via OnePlus 7 Pro , Aug 4, 2020 :
    Didn't get Live caption with 10.3.3 on my 7pro, will this update bring Live caption feature to my device?
    (Previously updated via oxygen updater, this time I'm going to wait for ota notification).
  10. pant_psi13
    Eclair Aug 4, 2020
  11. C1587352310498
    Cupcake Aug 4, 2020
    So, we may deduct that OP7's HW is lower quality than OP6 and in that case Does it worth it?
    Thanks
  12. Gav_W86
    Starting Point Expert Community Expert Aug 4, 2020
    Gav_W86 , Aug 4, 2020 :
    If people are reporting issues with it in beta then it won't go onto stable (well, that is the plan).
  13. Shalin235
    Insane_Butcher likes this.
  14. laikexpert
    laikexpert , Aug 4, 2020 :
    You can install Global version 10.3.4
    on your GM1913 Model
    On the Global version you have a louder sound.
    I have GM1913 Model
    and I just installed 10.3.4.GM21AA (Global)
  15. Gav_W86
    1. somepoint after it it finalised by Google.
    2. build paths for different phones are different, different updates at different times. don't compare numbers between different phones.
    ASCHENTE_V likes this.
  16. Gav_W86
    No. Just that it has had fewer updates.
  17. pant_psi13
    Eclair Aug 4, 2020
    pant_psi13 , via OnePlus 7 Pro , Aug 4, 2020 :
    Whatever i do it...but what's the difference between 10.3.4 and 10.0.7?
  18. c3drik67
    it's a little stu... reasoning. Op7 serie come out in 2019 and op6 in 2018. Not same release date,Not same phone, not same firmware, not same build not same bug ,not same number of build.
  19. Gav_W86
    There are some India specific features like a cricket score widget,
