129
OxygenOS 10.0.7 [EU] and 10.3.4 [India & Global] for the OnePlus 7 Pro and OnePlus 7
  1. UnicornZ
    Honeycomb Aug 26, 2020
  2. Luarpc
    Froyo Aug 26, 2020
  3. G_Amit_Soni_
    Cupcake Aug 26, 2020
  4. UnicornZ
  5. vishal13111
    Donut Aug 26, 2020
    vishal13111 , Aug 26, 2020 :
    is anybody else facing issue with Twitter app on OP7Pro?
    it keeps on crashing after screen freeze and multiple frame drops on my OP7PRO, all other apps r working fine except Twitter, I don't think it's an app related issue as no other android user is facing it
    can u guys please look into it..
  6. Luarpc
    Froyo Aug 26, 2020
    Luarpc , Aug 26, 2020 :
    That's not a "show off", i'm demonstrating that the issue with Wi-Fi speed on OnePlus phones it's not a problem from OnePlus, maybe a router settings or carrier services. I read here to many people complain about everything!!! When the problem is on their side. OnePlus can't do miracles!
    They are chronic complainers!
    I'm using 1+ 7 Pro 12Gb/256Gb for about 3 months and it's for sure the best phone i ever had, bought it with Android 9 Pie, updated to 10, updated again to 10.0.7GM21BA incremental update and never had problems after updates. Everything works with no bugs at all.
    This is a great phone with a great ROM OxygenOS. Loving it!
  7. KorokHidup
  8. rabzdxb
    Froyo Aug 26, 2020
  9. prabhu7212
    Froyo Aug 26, 2020
    prabhu7212 , via OnePlus 7 , Aug 26, 2020 :
    Dear one plus in all updates one thing is missing .. camer improvement such as chrome mode or color modes to be incorporated which will boost our camera experience..
    G_Amit_Soni_ likes this.
  10. rabzdxb
    Froyo Aug 26, 2020
    rabzdxb , Aug 26, 2020 :
    FC on OnePlus Contacts 4.0.0.0.200807234155.5606954 (OOS 10.3.4). Can someone please helpme solve this?
  11. jsantiagogomez
  12. rabzdxb
    Froyo Aug 26, 2020
  13. Gdsingh9
    Ice Cream Sandwich Aug 26, 2020
  14. rabzdxb
    Froyo Aug 26, 2020
  15. Swejuggalo , via OnePlus 8 Pro Ultramarine Blue , Aug 26, 2020 :
    2 possible solutions. Wipe data of the app. Check if you have an uninstall update in app info.
    If nothing really helps you may need to factory reset. Manually updating some of the Oneplus apps may break stuff. If it does not exist in Play Store it's usually best just to leave it alone.
    rabzdxb likes this.
  16. rabzdxb
    Froyo Aug 26, 2020
    Swejuggalo likes this.
  17. K1577121831829
  18. Artemus.
    Nougat Aug 26, 2020
    Artemus. , Aug 26, 2020 :
    Actually, it does. Are you using the stock power brick and red charge cable?
  19. K1577121831829
