118
OxygenOS 10.0.7 [EU and Global] and 10.3.1 [India] for the OnePlus 7T Pro
  1. ChefChaudart
    Honeycomb Mar 11, 2020
    ChefChaudart , Mar 11, 2020 :
    Oooops ;) A so silly reason to blame Oneplus, I thought it was a kind of joke :D
    "...Ruins Oxygen OS..." :p it made my day man !
  2. Swejuggalo
    KitKat Mar 11, 2020
    Swejuggalo , via OnePlus 7 Pro , Mar 11, 2020 :
    What exactly does that shortcut do? Limited to 7T series or from stock launcher?
  3. Swejuggalo
    KitKat Mar 11, 2020
    How have you downloaded? Where is the file and is it found by local upgrade?
  4. F1579226717741
    Donut Mar 11, 2020
    F1579226717741 , Mar 11, 2020 :
    ChefChaudart
    Oooops A so silly reason to blame Oneplus, I thought it was a kind of joke
    "...Ruins Oxygen OS..." it made my day man !​
    your a joke. OnePlus phones accidentally going silent all the time because of this shortcut is no joke. it is OnePlus fault because this shortcut is optional on stock Android.
  5. Fatih Aşkın , via OnePlus 7T Pro , Mar 11, 2020 :
    system updater did see update.zip and zip in the internal storage. everything fine.
    but i want update my system again with this file. when i select file and after then install, i seen %0 to %99 just 1sec. when bar %1oo, i clicked to reboot button. device shutdown and status bar haven't "update settings conf. stuff". and system not updated.
    why i want this?
    i had root access with magisk but i installed a module 2 days ago.
    this module is not compatible and device bootloop.
    after then, i flashed stock system image. and i haven't root access now.
    i tried my method before (previous update) and it's worked. but now, not update over to system again.
  6. F1579226717741
    Donut Mar 11, 2020
    Swejuggalo
    What exactly does that shortcut do? Limited to 7T series or from stock launcher?​
    it activate a faulty vibrate mode without symbol in statusbar, it doesn't matter if alert slider is in normal mode. stock software, no extra launcher, 7t pro. it only vibrate shortly after caller hangs up. do not disturb feature/bug.
  7. Swejuggalo
    KitKat Mar 11, 2020
    Ah. Does not happen here on 7 Pro and open beta channel. I use a software toggle (added an extra tile via Tiles) to enable vibrate mode. That software toggle does not show any status change either like the way hardware slider does. Only visible in the tile shortcut. So 7T series seems to have software toggle then but no way to disable usage of it. Seems like it needs an on off/toggle if you don't want that shortcut or atleast using the same visuals as slider to show that it is on/off.
  8. Swejuggalo
    KitKat Mar 11, 2020
    Do you still have unlocked bootloader?
    https://android.gadgethacks.com/how...actory-images-android-using-fastboot-0175277/
    Fatih Aşkın likes this.
  9. F1569770754130
    Cupcake Mar 11, 2020
    F1569770754130 , Mar 11, 2020 :
    Heating issues with moderate usage of apps like YouTube after the update..is anyone else facing this?
  10. Z1543035977841
    Cupcake Mar 12, 2020
  11. vincent.liu
    Froyo Mar 12, 2020
  12. B1582083592080
    Cupcake Mar 13, 2020
  13. ChefChaudart
    Honeycomb Mar 14, 2020
    E1581022147889 likes this.
  14. E1581022147889
    Gingerbread Mar 14, 2020
  15. Sameermehta2
    Honeycomb Mar 17, 2020
    Sameermehta2 , Mar 17, 2020 :
    Apologies for late reply hope your issue is resolved by now,I had some problems post updating from oxygen updater app so I had to use msmtool and rever to original firmware then again update it to this one,the tool is available on XDA just fyi
  16. G_sumit_azad_sMQC , via OnePlus 7T Pro , Mar 17, 2020 :
    Sometimes i am facing issue to attach a file or pic in WhatsApp. whenever i tried to attach the application got hang and i have to kill the application. on reopen of application the problem don't solved so i have to restart the phone i have reload the application twice but the same problem occurs sometimes is there any other who is facing the same issue with WhatsApp..... is it a application issue or system issue?
    Sathish Sharma likes this.
  17. cadeepakbansal
    Froyo Mar 17, 2020
    cadeepakbansal , via OnePlus 7T , Mar 17, 2020 :
    MAJOR BUG UNDER DARK MODE. (SCREENSHOT ATTACHED) switching to/from Dark mode will do these abrupt actions: - Music stops playing & Music player is Poweramp (purchased version) gets exit every time. - Network Bars displaces. - Battery Percentage disappears. - Dark mode does not work on Third Party apps. - Contacts, Phone app & various other apps are not giving proper colours.
    Neelavar Sumanth likes this.
  18. ngydat
    KitKat Mar 17, 2020
    ngydat , Mar 17, 2020 :
    I noticed that too (at least for the music player being stopped). You're welcome to submit this issue in the feedback section (I don't use my 7T anymore).
