121
OxygenOS 10.0.7 [EU and Global] and 10.3.1 [India] for the OnePlus 7T Pro
  1. ChefChaudart
    Honeycomb Feb 15, 2020
    Kethrildur likes this.
  2. Sunilsudha
    Froyo Feb 15, 2020
  3. mateo1597 , via OnePlus 7T Pro Haze Blue , Feb 15, 2020 :
    Is the Optimized Charging feature available in this update?
    I can't find it in the settings, and earlier OnePlus said that this feature will be pushed in the nearest update... So either i'm blind or its not available yet?
    OIC71 likes this.
  4. ChefChaudart
  5. OIC71
    Froyo Feb 15, 2020
    OIC71 , via OnePlus 7T Pro , Feb 15, 2020 :
    It doesn't? My wife got a 7T, and it does support VolTe/WiFi calling.
    Are you sure your network distributor supports this model? - both device and network distributor must support it, to work - otherwise you won't see the setting at all.
  6. D1576743758270
    Cupcake Feb 15, 2020
  7. satyamdua
    satyamdua , via OnePlus 7T , Feb 15, 2020 :
    Yes 7T supports VoWifi but my service provider(JIO) has not added 7t to the list of compatible devices. OnePlus 7T pro is present on that list. They added 7T pro after this update was rolled out.
  8. arun1092
    Gingerbread Feb 15, 2020
    arun1092 , Feb 15, 2020 :
    you can uninstall those..
  9. OIC71
    Froyo Feb 15, 2020
    Sad to hear.
    As you already are aware of, you have to speak with your service provider about it, instead of OP - they can't do anything about it.
    Kethrildur and satyamdua like this.
  10. AmanAli786
    Froyo Feb 15, 2020
    Y1581062267867 and satyamdua like this.
  11. Mrugav
  12. AmanAli786
    Froyo Feb 15, 2020
    AmanAli786 , Feb 15, 2020 :
    mine too
  13. EmmieT
    Donut Feb 15, 2020
  14. Deactivated User
    Feb 15, 2020
    nofoo likes this.
  15. Anoop Swamy
  16. Hugojburg
    Eclair Feb 15, 2020
    Sathish Sharma likes this.
  17. U1577109898645
  18. O1563452186083
  19. Oleg Trxnv
    Eclair Feb 15, 2020
    Oleg Trxnv , via OnePlus 7T Pro , Feb 15, 2020 :
    Open your Settings -> Apps and notifications. Find Google Play Market, stop the app and clear cache in memory settings. Try to launch it again.
  20. Deactivated User
    Feb 15, 2020
