115
OxygenOS 10.0.8 [EU] and 10.3.5 [India & Global] for the OnePlus 7 Pro and OnePlus 7
  1. ayushy4
    Eclair Oct 4, 2020
    ayushy4 , via OnePlus 7 Pro , Oct 4, 2020 :
    Nope, but you may risk your stable experience.
    Oneplus Nord users faced a bug which Factory Reset the devices. People lost all data.
    wes2go likes this.
  2. wes2go
    Cupcake Oct 4, 2020
    wes2go , via OnePlus 7 Pro , Oct 4, 2020 :
    Hmm, maybe I will hold off. Just got this and I don't wanna brick it right away. Thanks.
  3. P1577756714347
    Cupcake Oct 4, 2020
    P1577756714347 , Oct 4, 2020 :
    Hey guys, not only does 802.11w break 802.11r on Q it also appears to break VoWIFI so if your having issues with VoWIFI try to disable Frame Management Protection in router settings.
    Can someone confirm VoWIFI works with WPA 3?
  4. Last edited by a moderator: Oct 4, 2020
    B1571500439457, Abhik.b02 and wes2go like this.
  5. Swejuggalo
    OnePlus 9 Series Expert Community Expert Oct 4, 2020
    Swejuggalo , via OnePlus 8 Pro Ultramarine Blue , Oct 4, 2020 :
    I see no reason why WPA3 would make a differance with VoWiFi. In my case when preferring VoWiFi over mobile network it works perfectly fine. As far as I know VoWiFi demands is Internet access and carrier compability. I have never heard about a more detailed spec list of WiFi.
    I can't verifiy software issues on 7 series though.
    Artemus. and Deactivated User like this.
  6. wes2go
    Cupcake Oct 4, 2020
    Oh, I said earlier I should've been more specific. Mine isn't the T-Mobile branded version (GM1915), it's the one directly from OnePlus (GM1917) but I'm on the T-Mobile network. I just wanted to make sure that if I had updated it would still work on the network
  7. Pratt08
    Gingerbread Oct 4, 2020
  8. Swejuggalo
    The warning in the app only applies to the T-mobile branded phones. Unlocked version can update just like normal Oneplus phones.
    Artemus. likes this.
  9. wes2go
    Cupcake Oct 4, 2020
  10. wes2go
    Cupcake Oct 4, 2020
    Hmm, ok. I'll give it a shot then
  11. Python_Dev
    R1558620389427 likes this.
  12. wes2go
    Cupcake Oct 4, 2020
    wes2go , Oct 4, 2020 :
    Oh geez, thats like when someone tells me that food isn't spicy but I have no clue what that person considers spicy
  13. Last edited by a moderator: Oct 4, 2020
    wes2go likes this.
  14. wes2go
    Cupcake Oct 4, 2020
    I guess I'll wait another day or two to see if the OTA or website update comes out. This is my back up phone but I still like it keep it up to date. Thanks for your help and thanks everyone for your input as well.
    Deactivated User likes this.
  15. Vbj_OP_7
    Vbj_OP_7 , via OnePlus 7 , Oct 4, 2020 :
    After this update, 'Mark as read' and 'delete' options in notification panel for OnePlus messages app are not visible....are they gone or is it a setting??
  16. sahilrana
  17. Swejuggalo
    Speaking of spicy.... Carolina reaper beans 😜 We have had so much fun fooling people with them at work 😉 Even hid some amongst normal beans so some would grab a handful at once.
    Your phone model uses the same Global firmware as the rest. Once on Pie it got a region specific version once only for the NA model of the phone. But that is the only time I've seen it so far.
    But if it makes you feel safer and the rollout is slow for you... Take a look at the US version of Oneplus homepage. The update will sooner or later end up there too under Support, Software upgrades.
    Artemus., wes2go and Deactivated User like this.
  18. Artemus.
    Community Hero 2020 Oct 4, 2020
    Artemus. , Oct 4, 2020 :
    You absolute mad lad.
    Swejuggalo likes this.
