115
OxygenOS 10.0.8 [EU] and 10.3.5 [India & Global] for the OnePlus 7 Pro and OnePlus 7
  1. Siddhu16
    Eclair Oct 16, 2020
  2. Head_Hunter
    Gingerbread Oct 16, 2020
    Head_Hunter , via OnePlus 7 Mirror Blue , Oct 16, 2020 :
  3. bcharles99
    Honeycomb Oct 16, 2020
    Shalin05 likes this.
  4. sarahmic
  5. James 007
  6. 1bhavin12001
    1bhavin12001 , via OnePlus 7 Mirror Blue , Oct 16, 2020 :
    I have heard we shouldn't discharge battery to 0 as u did it....
    Do disabling developer option increase battery life and performance?....there shouldn't be much effect from my opinion.....
  7. Iamzb08
    Donut Oct 16, 2020
  8. Marco Apa , via OnePlus 7 Mirror Gray , Oct 16, 2020 :
    The timing of release is embarrassing...
    16 days and still nothing. But is it normal for a minor update all this time?
    And I'm still waiting for the fixes on the brightness and approach sensor reported via log.
    It is useless to make a thousand phones a year if you do not have the resources to keep them up to date and 100% functional.
    OnePlus attention that loses the prestige acquired!
  9. jatin0990
  10. mrmatrix
    Eclair Oct 16, 2020
    mrmatrix , via OnePlus 7 Pro , Oct 16, 2020 :
    I was probably by accident press someting when i was in developer option but i think that disabling it put all setting in developer back like there was. Also my battery draining was only when my wifi - mobile data was on but when i go to sleep and turn off wifi i had 2%, battery drain which is the best i ever had on this phone. Now on wifi is also normal. And you are right battery is amazing. So someone who has draining should find a bug or someting that is draining his battery, third part apps maybe. But i see you have 30°c but i think its normal if your apps are open or doing something.
    So im sure something of this fixed my battery: disabling developer option or updating android web view.
    This is two thing i did before noticing changes. said:
    Before
    Now (i dont use this up now when i dont have draining i just want you to show my temp)
    Both pictures are taken when all apps are closed.
    EDIT: also i was using adb shell on 10.0.7 and i had to use developer optoion for usb debuging.
  11. Udai Sharma
    Wahibmichael likes this.
  12. Last edited by a moderator: Oct 16, 2020
    1bhavin12001 likes this.
  13. iulisimo
  14. mrmatrix
    Eclair Oct 16, 2020
    I guess while i was scrolling i press something by accident. Also see if android web view updating is heliping.
    Before i had 15-20% draining per hour now its 8-10% per hour (SOT). Standby time is not important to mention because its amazing, almost no draining at standby.
  15. Last edited by a moderator: Oct 16, 2020
  16. mikex999
    Eclair Oct 16, 2020
    Yunusrg, 1bhavin12001 and James 007 like this.
  17. Last edited by a moderator: Oct 16, 2020
  18. mrmatrix
    Eclair Oct 16, 2020
    Hahaha i also was thinking there is no chance i did something by accident in developer optiob but i did hahahaha.
    I think turning off and on again resets developer settings.
    I see you turn off animation and all of that staff. And please dont tell me you are using 60hz? I actualy bought this phone because of 90hz. My pc is on 144hz and i can say i cant never go back on 60hz. Only thing i lower is resolution FHD+. I did it because i didnt see any difference.
  19. Nonochiken47
