19
OxygenOS 10.0.9 and 10.3.3 [India] for the OnePlus 7T Pro
  1. MgK79
    Donut Jun 21, 2020
    jnpblo likes this.
  2. D1572406744864
    Froyo Jun 21, 2020
  3. sjcruz
    Eclair Jun 24, 2020
    sjcruz , via OnePlus 7T , Jun 24, 2020 :
    Is there any way to make camera photos from being auto uploaded into google photos.evn if i made autosynchronization off still the pics taken in camera get loaded into photos section automatically
  4. Varyan , via OnePlus 7T Frosted Silver , Jun 24, 2020 :
    you can disable google photos from setting since oneplus already has it's own gallery app
  5. S1574684688688
    Cupcake Jun 24, 2020
    S1574684688688 , Jun 24, 2020 :
    same here too
  6. sjcruz
    Eclair Jun 25, 2020
    sjcruz , via OnePlus 7T , Jun 25, 2020 :
    Not able to do it...i tried...to
  7. sjcruz
    Eclair Jun 25, 2020
    Can u get me a screenshot of hw it looks if v made it off.i still face the same problem evn if i made auto synchronisation off on goog le.still cam photos gets loaded in google photos.
  8. Sammandot
    Cupcake Jun 25, 2020
    Sammandot , Jun 25, 2020 :
    hi, my notifications seems to be disappeared, when phone is on standby meaning when am on home page, I have to always slide down to see all kind of app notifications otherwise i don't see notifications. it's getting hide. how to get red of this. earlier i was able to see which notification received without sliding down from top. pls help asap
    Ebojager likes this.
  9. Varyan , via OnePlus 7T Frosted Silver , Jun 25, 2020 :
    just go to system settings-apps & notifications-show all apps & then select photos & disable it but it will remove google photos from your phone untill you re enable it
  10. sjcruz
    Eclair Jun 25, 2020
    Ya ya got it.wat i mean is why should a default backup setting given for camera to google photos.one plus can make it an optional.those who wish ll do it rest can ignore right.
  11. K1573628335229
    K1573628335229 , via OnePlus 7T , Jun 25, 2020 :
    Just visit the google photos app & then click on Albums option. In albums you will see a folder named camera open that folder than you will see a backup & sync option on the top right hand corner diaable that & now your photos won't backup in google photos app.
  12. Sammandot
    can anyone pls respond?
  13. saitobenkei
    Donut Jun 25, 2020
    saitobenkei , Jun 25, 2020 :
    Same issue here: After the phone is started, the screen turns off when the pin unlock request is made, but if you type above the screen, the digits are accepted.
    To make the image reappear, press the power key.
    OxygenOS 1.0.0.9.HD01BA
    Model: HD1913
    Iwan0903 and MgK79 like this.
  14. O1527671856964
    O1527671856964 , Jun 25, 2020 :
    plz add bottom gestures in 7t just like oneplus 6 on which we were so used to it..side button back gestures cause lot of confusion while operating in landscape mode
  15. sjcruz
    Eclair Jun 25, 2020
    Still its off.even though camera clicks appears in google photos app
  16. K1573628335229
  17. sjcruz
    Eclair Jun 25, 2020
    Ya tats right...suppose if v click our pvt pics and later v deleted from gallery and v might hav totally forgot to remove it from google photos...it may stay der for 60 days right until v delete it.suppose somebody scrolls phone it can be visible der....tats y i say default option shuld be removed
  18. K1573628335229
    sjcruz
    Ya tats right...suppose if v click our pvt pics and later v deleted from gallery and v might hav totally forgot to remove it from google photos...it may stay der for 60 days right until v delete it.suppose somebody scrolls phone it can be visible der....tats y i say default option shuld be removed​
    Ya that's a big problem & we have to face it as android & google photos are both the product of google. The one solution i can suggest is that you go into settings> privacy>permission manager>storage & in that kindly turn off the permission of photos app(i think it might work).
  19. K1573628335229
