128
OxygenOS 10.0.9 [EU] and 10.3.6 [India & Global] for the OnePlus 7 Pro and OnePlus 7
  1. mauryapankaj , via OnePlus 7 Pro Mirror Gray , Nov 11, 2020 :
    Ohee I thought this is feature given in this update.. but it's good while pickup the phone ring tone goes down.. no need to press volume button in some case
  2. appi1488 , via OnePlus 7 Pro Nebula Blue , Nov 11, 2020 :
    Go to phone dialler, then settings and in that open sounds & vibration. Check that you have that feature or not.
    D1524900378652 likes this.
  3. D1524900378652
    Cupcake Nov 11, 2020
    D1524900378652 , Nov 11, 2020 :
    Thanks [e]263a[/e]️ It worked [e]1f44d[/e]
  4. LabratPip
    Donut Nov 11, 2020
    LabratPip , Nov 11, 2020 :
    I'm having the exact opposite outcome as most of the posts in here. Still running QHD and 90Hz. My battery would typically be down to around 18-20% with that screen time in the previous update. This is matching the performance of the OS the phone shipped with.
    I'm wondering if this update is optimized for the op7pro w/ 12gb of ram? It seems to be underperforming with the other models.
  5. X1560044618028
    X1560044618028 , Nov 11, 2020 :
    Can anyone please help here as i am not able to call anyone because of this issue
  6. N1563935925671
  7. Cervantes
    Moderator Moderator Nov 11, 2020
    Cervantes , Nov 11, 2020 :
    Hi
    In the first post you have information to report a bug or in this: Link
    You can clean the app:
    settings> applications> phone> storage and cache> wipe cache
    or You can wipe storage and cache
  8. sam311
    Ice Cream Sandwich Nov 11, 2020
    Tedinetto likes this.
  9. H1561476019849
    Eclair Nov 11, 2020
  10. karna11
    Eclair Nov 11, 2020
    karna11 , Nov 11, 2020 :
    it same as before I got 8 hr sot
  11. Gatotp3
  12. LightningLdrago
  13. I1562869506998
    Gingerbread Nov 11, 2020
  14. L1569768949303
    L1569768949303 , Nov 11, 2020 :
    Batterylife is better then ever with last update (1.0.0.9 for Oneplus 7 pro)...of course I never play games
  15. nags92
    nags92 , Nov 11, 2020 :
    Great to see an update fully wipe my phone when i went into recovery....WITHOUT any prompt.
    (Y)
  16. appi1488 , via OnePlus 7 Pro Nebula Blue , Nov 11, 2020 :
    Read above comments, for calling ringtone loud problem
  17. N1563935925671
  18. bcharles99
    Honeycomb Nov 11, 2020
    bcharles99 , via OnePlus 7 Pro , Nov 11, 2020 :
    Open phone dialer>tap on 3 dots in right top corner>tap settings>sound and vibration>turn off ascending volume and also raise to lower volume
  19. Zex85
    S1540987544556 and SHP@7PRO like this.
  20. Ni3_chavan
    Froyo Nov 11, 2020
    Ni3_chavan , via OnePlus 7 , Nov 11, 2020 :
    can you plz share whole process of adb command
