129
OxygenOS 10.0.9 [EU] and 10.3.6 [India & Global] for the OnePlus 7 Pro and OnePlus 7
  1. R.Peter
    Ice Cream Sandwich Nov 17, 2020
    R.Peter , Nov 17, 2020 :
    Both are configured. I already forwarded the 500 and 4500 ports to my phone, so that won't block the connection, still, it doesn't work.
    I also set VoWifi to be preferred while calling, but only VoLTE works, the icon also shows it is so.
  2. G1562433915539
    Cupcake Nov 18, 2020
  3. Artemus.
    Community Hero 2020 Nov 18, 2020
    Artemus. , Nov 18, 2020 :
    Mobile network or WiFi?
  4. G1562433915539
  5. G1562433915539
    G1562433915539 , via OnePlus 7 Pro , Nov 18, 2020 :
    Mobile network. It's only icon glitch because if i go in settings, i see that mobile network switch off after airplane mode is activated. However icon still appears on.
  6. Artemus.
    Second SIM icon maybe?
  7. UnicornZ
    Ice Cream Sandwich Nov 18, 2020
    UnicornZ , via OnePlus 7 Pro Nebula Blue , Nov 18, 2020 :
    Can you connect to 2.4Ghz and in ur router page in 2.4GHz configuration change the bandwidth to 20MHz.
    Reason am saying this, I was using 5GHz with 40MHz bandwidth. Vowifi never worked. Then switched to 2.4Ghz and 20MHz bandwidth and it worked.
    R.Peter likes this.
  8. Vignesh Smith
    Froyo Nov 18, 2020
  9. DhavalA
    Froyo Nov 18, 2020
    DhavalA , via OnePlus 7 , Nov 18, 2020 :
    aakarshmodi
    Check your lock screen gesture setting. You might have set a gesture for flash light and you might be accidentally triggering it on.​
    There are no such options i found in settings. Google assistant is consistently opening now without even touching phone.
  10. Shalin05
    Honeycomb Nov 18, 2020
  11. Linkin1994
  12. Shalin05
    Shalin05 , via OnePlus 7 Pro , Nov 18, 2020 :
    Well on 10.3.4 with 90hz i was easily able to get 6.5 - 7 hrs. SOT here it even difficult to reach 6 hrs SOT.
  13. x_jayreghe_x
    Shalin05 likes this.
  14. G1562433915539
    I am using both SIMs and switching during a day. However in airplain mode mobile data icon keeps on hanging, no matter which sim card is chosen.
  15. R.Peter
    R.Peter , Nov 18, 2020 :
    I checked if the same setup solves the issue for me, but unfortunately it didn't. I turned off 5 GHz so only 2.4 GHz was available, I connected with my phone (checked on the router's UI and my device showed up under the 2.4 GHz band), then I set the bandwidth to 20 MHz, applied the changes. No luck, for few minutes I had no VoWifi nor VoLTE sign, later the VoLTE showed up.
  16. ZoroKoBoro
    U1549078778762 likes this.
  17. paritosh9199
    Gingerbread Nov 18, 2020
  18. MadyKarthi
    Yunusrg likes this.
  19. bcharles99
