128
OxygenOS 10.0.9 [EU] and 10.3.6 [India & Global] for the OnePlus 7 Pro and OnePlus 7
  1. Artemus.
    Community Hero 2020 Nov 7, 2020
    Artemus. , Nov 7, 2020 :
    There's nothing to fix. Games generate a lot of heat, that's the nature of the beast.
  2. SandeshChinchapur
    Jelly Bean Nov 7, 2020
    SandeshChinchapur , Nov 7, 2020 :
    I did the same thing, ended up installing apk but just after that i got an update on play store.
  3. SandeshChinchapur
    Don't think a problem, but anyways mine was replaced with stock from playstore by an update. Try searching from APK mirror.
  4. jagdish servi
    Gingerbread Nov 7, 2020
    jagdish servi , via OnePlus 7 , Nov 7, 2020 :
    I too had same problem I installed an very old version of it from apk mirror and updated from play store.
  5. jagdish servi
  6. Q1562476926477
    Cupcake Nov 7, 2020
  7. E1540483987494
    Cupcake Nov 7, 2020
    E1540483987494 , Nov 7, 2020 :
    After updating this version my ringtone is ascending when someone is ringing me
    can any one tell me where to reset this setting to back postion
    i cant hear the tone in ascending
    please share!!!!
  8. tejabhanus
    Cupcake Nov 7, 2020
  9. Sudeep Das India , via OnePlus 7 Pro , Nov 7, 2020 :
    I reluctantly updated from 10.3.4 to 10.3.6 through Oxygen Updater app after waiting for more than a month for the OTA update after announcement by oneplus. This shows that Oneplus 7 Pro, hailed as one of the best phones of 2019, is no longer the priority of oneplus, which is kinda sad. I did not get such step brotherly treatment even when I upgraded from oneplus 5 to oneplus 7 Pro. I remember way back then, oneplus 5 got Android 8 update even before the oneplus 6. Such were the times. I feel after the exit of Carl Pei, oneplus seems to be losing ground. I hope oneplus can be invent itself with renewed customer centric approach they had earlier. Maybe they can start with timely Android 11 update for Oneplus 7 series before the year ends. I can just hope.
    Q1562476926477 likes this.
  10. Nitzz_Raju , via OnePlus 7 Pro Mirror Gray , Nov 7, 2020 :
    In call setting u will find option for ascending ringtone.
    E1540483987494 likes this.
  11. epic_serj
    Cupcake Nov 7, 2020
  12. Sairam Venkata and AhmedZunaid like this.
  13. E1540483987494
    Cupcake Nov 7, 2020
    can you please elaborate it please i cant find it anywhere
  14. AhmedZunaid
    Honeycomb Nov 7, 2020
    AhmedZunaid , Nov 7, 2020 :
    There will be no update if you Download any of it via oxygen updater. I am at 10.3.4
  15. E1540483987494
    Cupcake Nov 7, 2020
    yeah i got it bro
    thank you[e]1f60a[/e]
    Nitzz_Raju likes this.
  16. TxGopi
    Froyo Nov 7, 2020
    TxGopi , via OnePlus 7 Pro , Nov 7, 2020 :
    I am using 6 more days this update 10 .3.6
    I facing no heating issue
    Perfect 👌 work
    Battery backup 👍
    Charging time no heating issue
    Normal time data on & gps full on no heating issue
    Ni3_chavan and Jigs218 like this.
  17. champ.krishna
  18. TxGopi
    Froyo Nov 7, 2020
    55 % battery use
    My screen on time 6 hrs
    Jigs218 likes this.
  19. MSChandru
    Cupcake Nov 7, 2020
    MSChandru , via OnePlus 7 Pro , Nov 7, 2020 :
    I updated the security patch 2020-09.
    Battery drains fast, I used continuous 73 minutes and the battery consumption were 31percent drains. Before the updating for the same 21percent consumption. Now draining fast.. please update the next security patch and too the horizontal lines not working while notification comes.
  20. Action_Pretty
    Action_Pretty , Nov 7, 2020 :
    FALSE! pls stop spreading this stupid rumour.
