1334
OxygenOS 10.0 for the OnePlus 6 and 6T
  1. Boubaker01
    Gingerbread Nov 3, 2019
    Boubaker01 , Nov 3, 2019 :
    guys, i downgraded My op6 to A9 beta 25 and i want it to be A9 stable (i downloaded the file of oxygen os 9.0.9 but the problem is that i don't know how to install it)after that i went to the system update and than local upgrade, i found a title that it says "move installation package to root directory".
    thanks for helping me.
  2. mischa1981
    Ice Cream Sandwich Nov 3, 2019
    K1535288571466 likes this.
  3. joseramonc
    Cupcake Nov 3, 2019
    joseramonc , Nov 3, 2019 :
    Hi guys! I just went from A10 open beta 1 to A10 stable version with out data lost. I just follow the instructions that oxygen uploder said before installing the stable version. I just rest my divice to factory settings and then when on to manual install the A10 stable version, without downgrading to A 9. Hope this info is worth some help.
  4. T1561288844109
    Cupcake Nov 3, 2019
  5. pocososinos
    Eclair Nov 3, 2019
  6. Q1550343616804
    Eclair Nov 3, 2019
  7. Aashish_Satpute
    Cupcake Nov 3, 2019
  8. KishD
    Froyo Nov 3, 2019
    KishD , via OnePlus 6T , Nov 3, 2019 :
    I don't understand your post. Resetting to factory defaults does wipe data.
  9. dermot33
    dermot33 , via OnePlus 6T , Nov 3, 2019 :
    can't seem to find an option to set the lockscreen wallpaper,have even tried using other apps but no joy,
    Is this an issue with A10 ?
  10. dm00389731
    Honeycomb Nov 3, 2019
    dm00389731 , Nov 3, 2019 :
    i think pie version is more smoother than 10
  11. Parth PK
    Eclair Nov 3, 2019
  12. dm00389731
    nd recent menu animantions are butterly smooth in pie version as compared to 10
  13. G_Rajat_Uppal_XbWp
    Cupcake Nov 3, 2019
    R1553199667484 likes this.
  14. S1570581786340
    Cupcake Nov 3, 2019
  15. leo_mihir10
    Eclair Nov 3, 2019
  16. oneplus6_mode
    Donut Nov 3, 2019
  17. loancorread
    Cupcake Nov 3, 2019
    loancorread , Nov 3, 2019 :
    After updating to Android 10 :( , I assume that's the reason I can't install Netflix. is there a way to fix it?
  18. joseramonc
    Cupcake Nov 3, 2019
    yes that's true, but I didn't do a wipe because i downgraded, I just did a factory rest and wipe all the data while i was still on A10 open beta 1. after I did that I downloaded the backup I did before doing the factory reset, restore all my data and then while I still was on a10 open beta 1, I manually install the A10 stable version and did not lose any of my resorte data.
    So is possible in my opinion to go from A10 open beta 1 to A10 stable without losing your data.
  19. drollfoot
    Cupcake Nov 3, 2019
    drollfoot , Nov 3, 2019 :
    After using the beta for 1 day I noticed that the screen lowered drastically for my oneplus 6t. Usually I het around 6 to 7 hours but now i het barely 5,5 hours
