1333
OxygenOS 10.0 for the OnePlus 6 and 6T
  1. vlsimadhavan
    Eclair Nov 3, 2019
  2. Sudhir_Samuel
    Gingerbread Nov 3, 2019
    Sudhir_Samuel , via OnePlus 6 , Nov 3, 2019 :
    It will be available to some users and reaches slowly to all the users in a week or 10days.
  3. M1572807772821
    Cupcake Nov 3, 2019
  4. Auristic
    Lollipop Nov 3, 2019
    Auristic , via OnePlus 6T , Nov 3, 2019 :
    None but you can find alternative options in this thread to get it /now...
    But you'll have to read instead of waiting to be spoon fed...
  5. Vinothkr7
    Cupcake Nov 3, 2019
    Vinothkr7 , Nov 3, 2019 :
    I installed android 10 through oxygen updater app its stable version?? chrome not updating is there any issue???
  6. Auristic
    It IS thé stable version but what's upgrading gotta do with Chrome !?
  7. Vinothkr7
    Cupcake Nov 3, 2019
    In d play store updates all apps updated only chrome download but not installing
  8. Auristic
    Reboot your phone, uninstall chrome updates you may have installed...
  9. Vinothkr7
    Cupcake Nov 3, 2019
    it's show frm last 1day.. installing installing but not installed
  10. Vinothkr7
    Cupcake Nov 3, 2019
    yae i did bro bt no use that's y i asked oxygen updater is good or not?
  11. docnok63
    Jelly Bean Nov 3, 2019
    docnok63 , Nov 3, 2019 :
    I did it for you, but here is visual explanation/proof...
    Once you download the installer, use 7-Zip or WinRAR to extract:
    Once done, payload.bin will be in there:
    Place payload.bin in payload_input directory and run payload_dumper.exe as an administrator:
    All extracted files will be in the payload_output directory including boot.img. Profit :D
    OP6T_10.0_stock_boot.img
    PapaMag likes this.
  12. Vinothkr7
    Cupcake Nov 3, 2019
    use oxygen updater app and check this app will show update
  13. Vivaan@98
    Cupcake Nov 3, 2019
  14. AlessioPorta
    Cupcake Nov 3, 2019
  15. Boubaker01
    Boubaker01 , Nov 3, 2019 :
    guys i want to upgrade from A9 Beta 25 to A9 Stable
    but i don't know how to do it , so plss help me
  16. Syedehaan
    Cupcake Nov 3, 2019
  17. PapaMag
    PapaMag , Nov 3, 2019 :
    Thank you this helps a bunch
    docnok63 likes this.
  18. Κώστας_Λασηθιωτάκης , Nov 3, 2019 :
    updated here with only minor things
    battery is looking ok
    wifi gps cell signal ok
    sound ok
    haptic feedback is very strong and that is a minor glitch for me.
    new gestures are hard to use (going back does not always work) but that was the glass screen protection to blame since it covers a tinny bit of the edge screen. so either more thumb force or no screen protector like that for me (the one with black border.
    colors on screen are good and accurate, measured with a spectrometer.
    settings is more like a maze than before for me. more settings under more settings, and some of them belong to another section. But that is how I see it.
    photo quality is the same shit it was before. cloudy not crispy and hazy. could always use gcam so no complains there.
    also I forgot. Viber notification becomes white while you close notification drawer
    overall I would say good job OnePlus.
  19. DjangoGroen
    Cupcake Nov 3, 2019
    DjangoGroen , via OnePlus 6T , Nov 3, 2019 :
    Maybe I look over it. But where is the download link so I can update it local via settings? I'm on the first android 10 beta now. I want the stable one
  20. Rishik999
    Honeycomb Nov 3, 2019
    Rishik999 , via OnePlus 6 , Nov 3, 2019 :
    reply please @crYSTal Z
