1334
OxygenOS 10.0 for the OnePlus 6 and 6T
  1. kustra2229
    Gingerbread Nov 4, 2019
    kustra2229 , Nov 4, 2019 :
    Don't cry.
  2. Atulit1
    Honeycomb Nov 4, 2019
    Atulit1 , via OnePlus 6 , Nov 4, 2019 :
    read the 2nd comment from the top. it will rolled out today for small group of people and later to rest.
  3. LegolasX
    Jelly Bean Nov 4, 2019
    LegolasX , Nov 4, 2019 :
    no you don't get changelog if manually updated using zip.
    Chinmaya Mahapatra likes this.
  4. Teja1999 likes this.
  5. syedrhashmi
    syedrhashmi , via OnePlus 6T , Nov 4, 2019 :
    I have done local upgrade from A10 Open Beta to A10 stable after backing up all my data.
    Shocked to see no data lose after upgrade Everything is same, only version is changed
    [e]1f44d[/e]
  6. Azaz.Waheed
    Cupcake Nov 4, 2019
    Azaz.Waheed , via OnePlus 6T , Nov 4, 2019 :
    i am having some issues like, On video call while connected to bluetooth headphones, my device gets hot around the camera, and it is also draining battery and using more RAM. Does anyone else facing such issues on there OnePlus 6T?
  7. DHARMIN JAGAD
    Cupcake Nov 4, 2019
  8. chahit93
    Cupcake Nov 4, 2019
    chahit93 , Nov 4, 2019 :
    Can anyone post updated bug list for OP6T?
    That way everyone could check and get back.
  9. NicestRudeGuy
    Froyo Nov 4, 2019
  10. chahit93
    Cupcake Nov 4, 2019
    Update directly with file download and Local upgrade option buddy.
  11. vikram bhat
    Donut Nov 4, 2019
    vikram bhat , Nov 4, 2019 :
    updated using OxygenOS upadate app, local update. EVERYTIME I SET TOUCH VIBRATION INTENSITY TO "LIGHT" IT GOES BACK TO "MEDIUM" IN A FEW MINS. THO IT STILL SHOWS ITS IN "LIGHT" I'LL HAVE TO TOGGLE IT AGAIN TO SET IT ON LIGHT...........
    Mandar_Sankhe likes this.
  12. syedrhashmi
    I already mentioned above, I didn't loose any data
    it will prompt you "data will be lost" while doing local upgrade. But after upgrade no data will be lost,
    However backing up is suggested
  13. NicestRudeGuy
    Froyo Nov 4, 2019
    NicestRudeGuy , via OnePlus 6 , Nov 4, 2019 :
    does the backup include app settings ? I only need backup of all apps and inside settings . can you confirm that
  14. M1543929202072
    Cupcake Nov 4, 2019
  15. M1543929202072
    Cupcake Nov 4, 2019
  16. syedrhashmi
    NicestRudeGuy
    does the backup include app settings ? I only need backup of all apps and inside settings . can you confirm that​
    You can do customized backup (as per your requirement) in OnePlus Switch App, and copy backed-up file in external drive.
    After upgrading you can restore the same from OnePlus Switch App if data is lost.
  17. R1530416269821
    Donut Nov 4, 2019
    R1530416269821 , via OnePlus 6 , Nov 4, 2019 :
    Thankyou so much
  18. I1556263169460
    Cupcake Nov 4, 2019
    ratansuthar00 likes this.
