1333
OxygenOS 10.0 for the OnePlus 6 and 6T
  1. S1541021483269
    Cupcake Nov 4, 2019
    S1541021483269 , via OnePlus 6T , Nov 4, 2019 :
    I have oneplus 6t, i updated to android 10 yesterday and i have got a lot of troubles.
    The Phone freeze a long time and when i try to launch an app the app start maybe 20 seconds later or not launch at all. [e]1f625[/e]
  2. Kensho
    Froyo Nov 4, 2019
  3. ravr
    Eclair Nov 4, 2019
    ravr , via OnePlus 6 , Nov 4, 2019 :
    Hello there, any further update? it's been a good time
  4. Jitender Malik
    Cupcake Nov 4, 2019
  5. ankitsharma012
    Cupcake Nov 4, 2019
  6. G_Seany_B_DnZF
    Cupcake Nov 4, 2019
  7. ArtuCer
    Gingerbread Nov 4, 2019
    ArtuCer , Nov 4, 2019 :
    Why you rollback?
  8. Adrian Asigurari
    Cupcake Nov 4, 2019
  9. V.Bosmia10
    Cupcake Nov 4, 2019
    V.Bosmia10 , via OnePlus 6T , Nov 4, 2019 :
    Having 6t, can i directly download from the link?
    I still didn't get the update in the "system update" option. So is it okay to download directly from the link?
  10. G_Seany_B_DnZF
    Cupcake Nov 4, 2019
  11. splinter_head
    Ice Cream Sandwich Nov 4, 2019
    splinter_head , Nov 4, 2019 :
    that update was yesterday, the update is rolling out slowly for both 6 Series phones.
    you won't see it immediately as it's a staged rollout. be patient
  12. ABHI170790
    Froyo Nov 4, 2019
  13. Z1553239049735
    Froyo Nov 4, 2019
    Adrian Asigurari likes this.
  14. vlsimadhavan
    Eclair Nov 4, 2019
    vlsimadhavan , Nov 4, 2019 :
    Factory reset after upgrade will be effective....
    Saurabh_Seth likes this.
  15. J1572860720296
    Cupcake Nov 4, 2019
    J1572860720296 , Nov 4, 2019 :
    hi im oneplus 6t owner after updated to android 10 my play protect certification are not certified and i can't install Netflix app which is listed as not supported device. how i can fix this problem thanks.
  16. Kensho
    Froyo Nov 4, 2019
    Kensho , Nov 4, 2019 :
    Are you sure you installed stable Android 10, because problem you described existed in early version of Beta.
  17. Elatchian Veeramani , via OnePlus 6 Silk White , Nov 4, 2019 :
    yea bro. i am aware of that. But just asking since there are plenty of things to be upgraded from Pie to Android 10 i thought to reset before upgrading also. is there will be any problem?
    vlsimadhavan likes this.
  18. bjrg
    Honeycomb Nov 4, 2019
    bjrg , Nov 4, 2019 :
    I know. I have been following all the recent developments.
