1333
OxygenOS 10.0 for the OnePlus 6 and 6T
  1. R@j@7
    Gingerbread Nov 5, 2019
  2. ArtiomCiobanu
    Froyo Nov 5, 2019
  3. kiranm25
    Eclair Nov 5, 2019
  4. Uday_1984
    Cupcake Nov 5, 2019
  5. R@j@7
    Ashmak Hirpara likes this.
  6. zilent771
    Cupcake Nov 5, 2019
    zilent771 , Nov 5, 2019 :
    Gpay works on 10OS? Update to A10 break gpay on my 6:( anybody can try to pay via gpay? [​IMG]
  7. ironass
    Lollipop Nov 5, 2019
    ironass , Nov 5, 2019 :
    Why not just install the new stock, stable, OxygenOS for Android 10, in Local Upgrade or use the Oxygen Updater app to download the full Android 10 stock firmware and install it.
    By the way, I think you will find that those Roll-Back, downgrade .zip files that you have linked to are for the Open Beta, OBT, Android 9 firmware.
  8. Dipkyadav
  9. Darsh89
    Donut Nov 5, 2019
    Darsh89 , via OnePlus 6T , Nov 5, 2019 :
    how to get rid of this android setup. i even connect wifi but setup didnt start and after restart the device it goes for some time and reappear i know the method to disable it from setting but is there any other way to go though it?
  10. sandy7874
    Donut Nov 5, 2019
    sandy7874 , Nov 5, 2019 :
    User from India who have udpated their OnePlus 6, can you please confirm UPI apps (Gpay, PhonePe and Paytm) works? did u encounter any issues with any popular/day to day apps?
    Rahul_Gavri likes this.
  11. R@j@7
  12. Yochrish
    Donut Nov 5, 2019
  13. Rahul_Gavri , via OnePlus 6 Midnight Black , Nov 5, 2019 :
    I'm a little late here, updating now and will let you know.
  14. sandy7874
    Donut Nov 5, 2019
    Thank you!
    The reason being I use these apps regularly/frequently. So if these are working fine, I will update; else I will wait for further patches.
  15. Artemus.
    Community Hero 2020 Nov 5, 2019
    Artemus. , Nov 5, 2019 :
    Connect to WiFi, open Google Play Store and let it start the update process.
  16. Matteo Pio
    Cupcake Nov 5, 2019
    Matteo Pio , via OnePlus 6 , Nov 5, 2019 :
    Hi guys. Just updated to Android 10 on my OnePlus 6, and as in the open beta the WiFi MAC address changed. The device doesn't want to connect to some 5Ghz networks, if they have a separated SSID on the router. I hope OnePlus will fix this as soon as possible
  17. Darsh89
    Donut Nov 5, 2019
    i connected wifi and clicked on that notification it doesn't worked. lets try by ur method thanx for reply bro.
  18. K1539522821760
    Froyo Nov 5, 2019
    K1539522821760 , via OnePlus 6 , Nov 5, 2019 :
    i am update pie to Q full OTA download from XDA site than select local update that's it
    after update my mobile working well but shown two files explore
  19. Z1543297170011
    Cupcake Nov 5, 2019
    Z1543297170011 , via OnePlus 6 , Nov 5, 2019 :
    Hi. i'm currently on oxigen os 9.0.8 and with root.
    it is possible to install directly oxygen os 10? or i have to pass from oxygen os 9.0.9?
    thanks
    G
  20. kashif.khan
    Cupcake Nov 5, 2019
