1334
OxygenOS 10.0 for the OnePlus 6 and 6T
  1. Lupastro82
    Gingerbread Nov 5, 2019
  2. Sagarthukral
    Eclair Nov 5, 2019
    Sagarthukral , via OnePlus 6 , Nov 5, 2019 :
    Screen calibration is bad on Android 10. was much better on 9 for the OnePlus 6. Now it's more warm. Yellow tinge doesn't really look great.
    Seems like the Blue light filter is always on in all settings except AMOLED Wide Gamut which saturates other colours
  3. Arun@prathap2019
    Cupcake Nov 5, 2019
  4. Jitender_Malhotra
    Cupcake Nov 5, 2019
  5. Sank93
    Eclair Nov 5, 2019
    Sank93 , via OnePlus 6 , Nov 5, 2019 :
    Still haven't received the update??
  6. F_Aryan_Gupta_yrRx
    Cupcake Nov 5, 2019
  7. splinter_head
    Ice Cream Sandwich Nov 5, 2019
    splinter_head , Nov 5, 2019 :
    If it's not showing up in System Updates for you, then it hasn't reached your device yet.
    Two options:
    1) Be patient, it will come in the next few days
    2) Install Oxygen Updater from the Play Store and follow the instructions in there to install the updat
  8. AbhireeshVijayan
    Donut Nov 5, 2019
  9. m.sa1981
    Cupcake Nov 5, 2019
  10. as_if_i_am
    as_if_i_am , via OnePlus 6T , Nov 5, 2019 :
    below Keyboard extra padding . Its using the screen space. It looks like button are there but hidden in gesture mode too. Anyone have any fixes for Android 10 OP6T update ?
    Tested in both geature mode settings and the space is there at the bottom of keyboard. Same in swift keyboard too.
    Updated from Oxygen Updater app.
  11. splinter_head
    This is a common problem with OxygenOS 10 on all OnePlus devices and keyboards. Hopefully this will get fixed in a later update
    asifansaringp likes this.
  12. Ravinder025
    Cupcake Nov 5, 2019
  13. as_if_i_am
    Gesture are also often stuck in between and not working many times. For example mostly home gesture is not working 10 times a day.
  14. Murali Krishnaa
    Eclair Nov 5, 2019
    Murali Krishnaa , Nov 5, 2019 :
    1. Yes, you'll need to downgrade to Android 9 and then check for System update or
    2. Download Android 10 stable OTA update and install.
    PLEASE NOTE: Either way there are chances that your personal data may be lost so please make a back up of your data.
  15. OneplusExtreme
    Froyo Nov 5, 2019
    OneplusExtreme , Nov 5, 2019 :
    Is this update stable? Are there any annoying bugs? I really can't be bothered to downgrade because of it which will lose my data
  16. Vinodroyal
    Cupcake Nov 5, 2019
  17. michaelsage
    Donut Nov 5, 2019
    michaelsage , Nov 5, 2019 :
    Yes. I am too
  18. Sahil1125
    Cupcake Nov 5, 2019
  19. desmondloh1997
    Cupcake Nov 5, 2019
    desmondloh1997 , Nov 5, 2019 :
    Just got my OnePlus 6 upgraded to Android 10 and it's really cool and stuff but the keyboard has a little too big of a gap at the bottom which is kind of annoying to look at though not a very significant issue. Everything is working as expected with improved privacy settings and customizations. Gcam mod need to be changed to a later one though. Overall rating would be 8/10.
