1334
OxygenOS 10.0 for the OnePlus 6 and 6T
  1. Farhanmohmmd
    Cupcake Nov 5, 2019
    robin143 likes this.
  2. G_jay_makwana_wuin
    Eclair Nov 5, 2019
  3. DurchEins
    Eclair Nov 5, 2019
    DurchEins , via OnePlus 6 , Nov 5, 2019 :
    How do I create a screenshot with Android 10? The hardware buttons do not work.
    and the space between the keyboard and the floor is really ugly ..
  4. BharAth.007
    Froyo Nov 5, 2019
  5. Muhammad_Kashif_bahl , via OnePlus 6 Silk White , Nov 5, 2019 :
    Quick setting notification panel is still accessible and can be changed or on/off any option through buttons provided in quick setting, while the phone is locked, it is still accessible and you can change or on/off any thing etc. data, location, wifi or flight mode. You can off your set even after the phone is lock and without unlocking your phone.
    WHY.....??? IT SHOULD BE PROTECTED TO SECURE SET OR LOCATE SET IF SOMEBODY THEFT IT. WHY... WHY... WHY...????
  6. DeluxeNoone
    Ice Cream Sandwich Nov 5, 2019
    DeluxeNoone , Nov 5, 2019 :
    Hide Notch ( display cutout) option is currently unavailable on this version
  7. splinter_head
    splinter_head , Nov 5, 2019 :
    There is a way to hide the notch using a Play Store app called "Activity Launcher" and searching in it for "Notch"
    rahulretnakumar likes this.
  8. Dante69
    Froyo Nov 5, 2019
  9. Gameslayer
    Gingerbread Nov 5, 2019
  10. robin143
    Honeycomb Nov 5, 2019
    robin143 , Nov 5, 2019 :
    Problems I experienced with Android 10 OnePlus 6 in a short time...
    . I hear a loud sound of the notification in the earpiece while on a call.. its weird and the sound is uncomfortable because of this notification sound during a call. Before it was not loud and it was comfortable
    Two google pays, one is different from the another.
  11. jain.mehul.
    Donut Nov 5, 2019
    jain.mehul. , Nov 5, 2019 :
    I have updated my OnePlus 6 to Android 10 today, but I am facing a bit problem with the keyboard. it has actually shifted upward, from the notch and I don't know why is it so, I am using the navigation bars (bottom) one. so can it be done back to bottom near the notch, it is quite handy then what it is now, and I am facing much problem to type as you people had shifted it upwards from the bottom.
    I am attaching a SS at the bottom of the keyboard !!!
    Ardeleanu likes this.
  12. praveenmohan6
    Cupcake Nov 5, 2019
    praveenmohan6 , via OnePlus 6 , Nov 5, 2019 :
    its included
  13. rahulretnakumar
    Cupcake Nov 5, 2019
    rahulretnakumar , via OnePlus 6 , Nov 5, 2019 :
    thank you , that really worked .
  14. TheRaVaN0.2
    Donut Nov 5, 2019
  15. I1546897729761
    Cupcake Nov 5, 2019
  16. bhargavkukadiya
  17. Gav_W86
    Starting Point Expert Community Expert Nov 5, 2019
  18. TheRaVaN0.2
    Donut Nov 5, 2019
  19. splinter_head
    The updated are staged updates so are slowly rolling out to sets of users. You have two options to get the update
    1) Wait. The update will hit your device at some point over the next few days. This is normal in the world of Android updates
    2) Download a Play Store app called "Oxygen Updater" and use that to download and install the update locally.
    - This is the method I used to install the Android 10 update and it is safe, reliable and works perfectly
    I1546897729761 likes this.
