1328
OxygenOS 10.0 for the OnePlus 6 and 6T
  1. splinter_head
    Ice Cream Sandwich Nov 5, 2019
    splinter_head , Nov 5, 2019 :
    You don't need the OTA update if you have updated via Oxygen Updater. They are the same update
  2. splinter_head
    Give it a few days to settle, Android does some background housekeeping after an update like this
  3. G_Sachin_Somvanshi_tjik
    Donut Nov 5, 2019
  4. S1541861021938
    Cupcake Nov 5, 2019
  5. mariogold42
    Honeycomb Nov 5, 2019
  6. splinter_head
    The update will hit your device in a few days as this is a staged rollout.
    If you are impatient then you may be interested in "Oxygen Updater" on the Play Store which can fasttrack the update to your device
    - This is what I used and it is fast, safe, stable and I can't see any bugs on my phone with the update
    Dolly Deshmukh and Abbas2348 like this.
  7. JuAnCaStRoP
    Gingerbread Nov 5, 2019
  8. G_Sachin_Somvanshi_tjik
    Donut Nov 5, 2019
  9. splinter_head
    If they are little curvy lines, they are prompts for the new gestures to bring up the Assistant. If you successfully swipe up from the lines and use it to answer a few queries (use each side a couple of times) they go away
  10. mariogold42
  11. splinter_head
    Oxygen Updater pulls the official OTA directly to your device, so they are exactly the same
  12. mariogold42
    mariogold42 , via OnePlus 6 , Nov 5, 2019 :
    swiping on it does nothing
  13. splinter_head
    The white line is the new gestures bar, you can change it or hide it in the Gestures menu of Settings
  14. splinter_head
    It's an awkward one, but it works. I did it on mine about 4/5 times.
    quick little flicks of the thumb usually work
  15. ironass
    Lollipop Nov 5, 2019
    ironass , Nov 5, 2019 :
    Wrong!
    Just install the full new stock, stable, OxygenOS for Android 10, via Local Upgrade or use the Oxygen Updater app to download the full Android 10 stock firmware and install it. No data loss.
    Open Beta questions should be posted in that thread.
  16. Z1572354089126
    Cupcake Nov 5, 2019
    Z1572354089126 , Nov 5, 2019 :
    Does anyone know if this will become a system update from the menu or if this has to be done OTA or through the Oxygen Updater only. I'm just trying to find the best way to do this without changing any of my settings because I don't know whether to root my phone or do incremental updates. I'm just concerned that either of those two other options would be less stable.
  17. C1539910430311
    Cupcake Nov 5, 2019
    C1539910430311 , Nov 5, 2019 :
    OK got it... Thanks bro
  18. JuAnCaStRoP
    JuAnCaStRoP , via OnePlus 6T , Nov 5, 2019 :
    splinter_head
    The white line is the new gestures bar, you can change it or hide it in the Gestures menu of Settings[/QUOTE
    Found it. Thanks ​
  19. splinter_head
    No upgrade options require root or have data / settings loss.
    OTA is the slowly rolling out update which will eventually show up in the System menu, whereas Oxygen Updater will pull the same update from the servers pro-actively. It just depends if you want to wait or not.
    Once you do it one way you don't need to nor will you be prompted to upgrade the other way, but it doesn't matter as they are the same update.
    Moving from OS9 => OS10, I would recommend a Fill Upgrade (if using Oxygen Updater).
    I used this method and I have a succesful upgrade with no bugs (I can use Google Pay, etc)
  20. Abbas2348
    Cupcake Nov 5, 2019
    Abbas2348 , via OnePlus 6 , Nov 5, 2019 :
    sitthaarrth
    Updated to Android 10 for OnePlus6 using Oxygen Updater.​
    it updates automatically or do you have to move the file in some storage??
    also which update did you choose full or incremental?
    sitthaarrth likes this.
