1324
OxygenOS 10.0 for the OnePlus 6 and 6T
  1. splinter_head
    Ice Cream Sandwich Nov 5, 2019
    splinter_head , Nov 5, 2019 :
    No upgrade options require root or have data / settings loss.
    OTA is the slowly rolling out update which will eventually show up in the System menu, whereas Oxygen Updater will pull the same update from the servers pro-actively. It just depends if you want to wait or not.
    Once you do it one way you don't need to nor will you be prompted to upgrade the other way, but it doesn't matter as they are the same update.
    Moving from OS9 => OS10, I would recommend a Fill Upgrade (if using Oxygen Updater).
    I used this method and I have a succesful upgrade with no bugs (I can use Google Pay, etc)
  2. Abbas2348
    Cupcake Nov 5, 2019
    Abbas2348 , via OnePlus 6 , Nov 5, 2019 :
    sitthaarrth
    Updated to Android 10 for OnePlus6 using Oxygen Updater.​
    it updates automatically or do you have to move the file in some storage??
    also which update did you choose full or incremental?
    sitthaarrth likes this.
  3. singhvarun48sv@g
    Cupcake Nov 5, 2019
  4. splinter_head
    Oxygen Updater downloads the file to your device, then you use the system menu to load that file locally from where it is.
    No need to move anything when using Oxygen Updater
  5. splinter_head
    The update will hit your device in a few days as this is a staged rollout.
    If you are impatient then you may be interested in "Oxygen Updater" on the Play Store which can fasttrack the update to your device
    - This is what I used and it is fast, safe, stable and I can't see any bugs on my phone with the update
  6. faisal.sidekick
    Gingerbread Nov 5, 2019
  7. T1572966389131
    Cupcake Nov 5, 2019
    T1572966389131 , Nov 5, 2019 :
    what about hiding the notch ,how can this be classed as an official stable update when features are missing .
  8. sitthaarrth
    Froyo Nov 5, 2019
    sitthaarrth , via OnePlus 6 , Nov 5, 2019 :
    chose local upgrade in system updates
  9. splinter_head
    Notch hiding is still available
    Download "Activity Launcher" from the Play Store, search inside it for "notch" and open the only option in there which takes you to the Phone's notch settings
  10. souravka6
    souravka6 , via OnePlus 6 , Nov 5, 2019 :
    not yet received.. still waiting....
  11. Susindharen
    Froyo Nov 5, 2019
    Susindharen , via OnePlus 6 , Nov 5, 2019 :
    mine was on September but it asked for an update now it went back to October after the update[e]1f602[/e][e]1f602[/e]
  12. Abbas2348
    Cupcake Nov 5, 2019
  13. sitthaarrth
    Froyo Nov 5, 2019
    not possible, may try be try disabling it, so it will be hidden.
  14. T1572966389131
    Cupcake Nov 5, 2019
    thank you , works a treat ,but why are OnePlus hiding this from general users if the option is still there ?
  15. sitthaarrth
    Froyo Nov 5, 2019
  16. Abbas2348
    Cupcake Nov 5, 2019
  17. splinter_head
    Just seems like an oversight in the settings, not hooking the Activity to the menu
  18. Abbas2348
    Cupcake Nov 5, 2019
  19. R1565438083151
  20. sitthaarrth
    Froyo Nov 5, 2019
