1322
OxygenOS 10.0 for the OnePlus 6 and 6T
  1. souravka6
    Gingerbread Nov 5, 2019
  2. T1572966389131
    Cupcake Nov 5, 2019
    T1572966389131 , Nov 5, 2019 :
    I do know I was running the A10 beta and in the update it says hide notch option was removed . I know and expect new software to have bugs and that but such simple but obvious "oversights" concern me.
  3. splinter_head
    Ice Cream Sandwich Nov 5, 2019
    splinter_head , Nov 5, 2019 :
    Have you been through the customization menu to tweak it? there's also a couple of light themes
  4. Dolly Deshmukh
  5. cas8180
    cas8180 , via OnePlus 6T , Nov 5, 2019 :
    I didn't give a Android 9 a week to "calibrate" itself after a complete wipe and rollback it just worked. bottom line Android 10 is too new. It was not properly optimized the way 9 was that had almost a year of develop and interactions tuning it.
  6. souravka6
  7. cas8180
  8. JustAPhone
  9. sitthaarrth
    Froyo Nov 5, 2019
    sitthaarrth , via OnePlus 6 , Nov 5, 2019 :
    i tried it, but didn't like it though, i was using dark theme earlier. now all apps changed to dark theme, example instagram, i dont like it with dark theme.
  10. Vinay tawar
    Cupcake Nov 5, 2019
    shantanunaresh likes this.
  11. rsr1+6
    Cupcake Nov 5, 2019
    rsr1+6 , Nov 5, 2019 :
    link to update 10
  12. HardeepHanda
    Eclair Nov 5, 2019
  13. sitthaarrth
    Froyo Nov 5, 2019
  14. splinter_head
    It's still a safe, reliable and stable way to force the update 90% of people on here have used it and I personally used it for each of the Android 9 updates that came my way
  15. sitthaarrth
    Froyo Nov 5, 2019
    May be you can try oxygen updater app.
  16. JustAPhone
  17. T1572966389131
    Cupcake Nov 5, 2019
    I've noticed I certain apps when notch is hidden ,like chrome etc it doesn't display time etc in status bar but when you screenshot the app the time etc displays . weird little bug
  18. L1572850348748
    Cupcake Nov 5, 2019
    L1572850348748 , Nov 5, 2019 :
    where is the updated ???...i am waiting from 2nd since you have given the updated..why its taking so long??
  19. Auristic
    KitKat Nov 5, 2019
  20. splinter_head
    You could run a hashcheck on the file, as long as you have the original SHA256 or something?
    Or download Oxygen Updater which pulls the update direct from the 1+ servers
