1333
OxygenOS 10.0 for the OnePlus 6 and 6T
  1. ArturSantos83
    Eclair Nov 5, 2019
    ArturSantos83 , via OnePlus 6 , Nov 5, 2019 :
    After hesitating for a few hours, I decided to install Android 10 on my OP6 using the Oxygen Updater app that I'd used before.
    Now I'd to share my personal brief experience so that anyone thinking about manually updating can make up their minds.
    1. The overall performance is brilliant. Still, it's not perfect, as unlocking the phone is a bit slower for example, but overall it is not as bad as some pointed out (just my experience, so mileage may vary here)
    2. My security patch is October 2019
    3. Every app I've tried works perfectly, although I haven't tried to pay with my phone yet
    4. No sudden reboot or data loss
    5. There are some inconsistencies on black/dark colours
    6. Still too soon to judge on battery life but it's perfectly fine at the moment
    7. I've just found an issue while typing this, as I can't scroll down while typing, so I can't see what I'm doing...
    Hope this helps some to figure out what to do, but I would probably suggest you wait until it is fully released.
    Btw: I think OP rushed quite a bit here, but they've been amazing so far, so let's hope they can sort it out ASAP.
  2. Viktri
    Donut Nov 5, 2019
    Viktri , Nov 5, 2019 :
    With older updates or patches I have tried the OxygenOS Updater App and it's very convenient. In this case, I am hesitating only since OnePlus pulled/delayed the update to OP6 due to a fingerprint bug and I am just waiting in case if other bugs are reported by the community and they are intentionally delaying the OTA, it is best to hold off and be patient till it hits our phones.
    I could and most likely be wrong and as most of the others have done, it could well be all good via the Updater app too! Just a matter of how desperate one is to get this version! :)
    avrahta and K1571477336208 like this.
  3. splinter_head
    Ice Cream Sandwich Nov 5, 2019
    splinter_head , Nov 5, 2019 :
    Yes. It is made and supported by OnePlus fans (note: Not OnePlus)
    90% of people here (including me) have used it to do their upgrade
  4. splinter_head
    The update will hit your device in a few days as this is a staged rollout.
    If you are impatient then you may be interested in "Oxygen Updater" on the Play Store which can fasttrack the update to your device
    - This is what I used and it is fast, safe, stable and I can't see any bugs on my phone with the update
  5. Kodama-consulting
    Cupcake Nov 5, 2019
    Kodama-consulting , Nov 5, 2019 :
    Check tour apn settings
  6. Abdullashaikh
    Honeycomb Nov 5, 2019
    Abdullashaikh , via OnePlus 6 , Nov 5, 2019 :
    Exactly.
  7. splinter_head
    I don't think that Oxygen Updater couldn't pull the paused update. I think it only gets access to the fully released OTA files, and judging by my personal update - everything is fine :)
    Viktri likes this.
  8. Xeon5
    Donut Nov 5, 2019
    Xeon5 , Nov 5, 2019 :
    Has anyone found the option to change the notch display? Tried searching but it just came up with the developer options. Maybe it has been removed?
  9. Kundanplanet
    Cupcake Nov 5, 2019
  10. splinter_head
    Notch hiding is still available
    Download "Activity Launcher" from the Play Store, search inside it for "notch" and open the only option in there which takes you to the Phone's notch settings
  11. splinter_head
  12. PiTRiS87
    Gingerbread Nov 5, 2019
    schreder and splinter_head like this.
  13. ManishGoswami19
    Cupcake Nov 5, 2019
  14. Łukasz_Kostrzewa
    Eclair Nov 5, 2019
    Łukasz_Kostrzewa , Nov 5, 2019 :
    Hi. I found another bug in android 10. Audio tuner isn't working. And it is not translated yo Polish language:(
    (offcourse I connected my headphones)
  15. J1558288802960
    Donut Nov 5, 2019
    J1558288802960 , Nov 5, 2019 :
    anyone from India Bangalore region.. I'm eagerly waiting for the OTA update for my OnePlus 6t but which is not received yet.. any one got the update in our location ?
    avrahta and S1537372471544 like this.
  16. vlsimadhavan
    Eclair Nov 5, 2019
    vlsimadhavan , Nov 5, 2019 :
    Nooo
  17. Delta___GoLu
    Cupcake Nov 5, 2019
  18. S1537372471544
    Cupcake Nov 5, 2019
    splinter_head likes this.
  19. splinter_head
    Please detail the bugs you are seeing. It's much more helpful to say what the bugs are, rather than just that there are some
  20. kmaier
