1319
OxygenOS 10.0 for the OnePlus 6 and 6T
  1. Rezwanrawnak
    Cupcake Nov 5, 2019
    Rezwanrawnak , via OnePlus 6 , Nov 5, 2019 :
    check vibration and did you rest your after update??
  2. p@r!m@|
    Donut Nov 5, 2019
  3. G1542828796976
    Gingerbread Nov 5, 2019
  4. kherson1973
    Cupcake Nov 5, 2019
  5. B1528565306298
    Eclair Nov 5, 2019
    B1528565306298 , Nov 5, 2019 :
    It has lots of bugs and flaws in it, i am listing down some of it which i encountered in merely a day use-
    1. Recent app animation -
    - it is very slow in compared to that of the earlier one
    - plus it works only when finger is swiped really high on the screen
    - also when dismissing recent app (without closing any app) apps swipes on to the left for smoother transition but it is making functionality of phone even slower
    2. Keyboard-
    - while typing, keyboard get raised up a little from the bottom leaving a black bar because of which now letter position is shifted from the usual one and thus leading to a very annoying typing experience.
    kuldeep_simar likes this.
  6. T1570027087874
    Donut Nov 5, 2019
    T1570027087874 , via OnePlus 6 , Nov 5, 2019 :
    Rezwanrawnak
    check vibration and did you rest your after update??​
    the vibration intensity has increased and there is no issue in it so far.i did not factory reset the device yet.
  7. Sudhir_Samuel
    Sudhir_Samuel , via OnePlus 6 , Nov 5, 2019 :
    Pls refer intro of this thread... U will get the answer
  8. G1542828796976
  9. Sudhir_Samuel
    Got it.. And using it from last 17hrs..try using oxygen updater app in playstore bro
  10. dbedbak
    Cupcake Nov 5, 2019
  11. Raghu2706
    Honeycomb Nov 5, 2019
    Raghu2706 , via OnePlus 6 , Nov 5, 2019 :
    I've got exactly the same Problem. try to Switch from "only wpa2" to "WPA/wpa2" in your Modem and then it should Work. seems to be a protocol Problem between Android 10 and some Modem manufacturors.
    I took the above statement from post #63. please try if it can help u
  12. Raghu2706
    Do u find any issues or bugs? What is ur model?
  13. F_Shiva_Teja_kgQO , via OnePlus 6 , Nov 5, 2019 :
    thanks bro
    any bugs so far??
    in comments they are mentioning so many bugs...
  14. Floy3D
    Cupcake Nov 5, 2019
  15. Kenshi_blind_MDYH , via OnePlus 6T , Nov 5, 2019 :
    I'm sitting here and wondering if we got different update packages lol...I downloaded the update through oxygen updater and I was stable android pie 9.0.17
    all my apps and PlayStore where up to date
    I charged my phone to 100%
    I then applied the update (local update and partial file) and voila
    no reboot or freezes since I updated.
    fingerprint works fine
    no PlayStore issue
    battery life is awesome even better than on pie
    the screen is a little bit yellow ish but that will surely be fixed in a following update
    the only issue I had (not really an issue) was the space at the bottom of the keyboard.i just used the and shell command to "fix"
  16. kuldeep_simar
    Cupcake Nov 5, 2019
  17. Sasi031197
    Eclair Nov 5, 2019
    Sasi031197 , via OnePlus 6 , Nov 5, 2019 :
    still i haven't received my update
  18. robin143
    robin143 , Nov 5, 2019 :
    I hear a loud sound of the notification in the earpiece while on a call.. its weird and the sound is uncomfortable because of this notification sound during a call. Before it was not loud and it was comfortable..... The notification sound during a call cannot be decreased even the ear speaker volume decreased.
    Do you have that problem ?
    Sahilkum and D1554303944054 like this.
