1320
OxygenOS 10.0 for the OnePlus 6 and 6T
  1. N1528436517540
    Eclair Nov 5, 2019
  2. Shreyas_j25
    Donut Nov 5, 2019
  3. Alex1681
    Gingerbread Nov 5, 2019
  4. Sagar905
    Cupcake Nov 5, 2019
  5. robin143
    Honeycomb Nov 5, 2019
    robin143 , Nov 5, 2019 :
    I hear a loud sound of the notification in the earpiece while on a call.. its weird and the sound is uncomfortable because of this notification sound during a call. Before it was not loud and it was comfortable..... The notification sound during a call cannot be decreased even the ear speaker volume decreased.
    Do you have thatproblem ?
  6. T1570027087874
    Donut Nov 5, 2019
    T1570027087874 , via OnePlus 6 , Nov 5, 2019 :
    try the screen calebration in setting and set it to advance AMOLED wide gammet it will sole the yellownesh in your screen
  7. Ltd2651
    Donut Nov 5, 2019
    Ltd2651 , Nov 5, 2019 :
    Under Screen Calibration, change your screen temp to the cooler side. I noticed that too. Should fix that issue.
  8. Pirati81
    Eclair Nov 5, 2019
    Pirati81 , Nov 5, 2019 :
    VPN is not working tried several times. Working fine in previous versions. Oneplus 6 A6000 model
  9. daydreamerx
    Cupcake Nov 5, 2019
  10. V1561191140685
    Cupcake Nov 5, 2019
  11. Kenshi_blind_MDYH , via OnePlus 6T , Nov 5, 2019 :
    no I don't have that issue...matter of fact I spent the day with my earphones listening to music and answering calls while working from home
  12. AkshatDev99
    Cupcake Nov 5, 2019
    AkshatDev99 , Nov 5, 2019 :
    The keyboard is a little above, it looks like its floating.
    I am using oneplus 6 and its the stable version of Android 10
  13. iamkrafi
    iamkrafi , via OnePlus 6 Midnight Black , Nov 5, 2019 :
    After updating my op6 loudspeaker volume got reduced. After updating most of my incoming calls are Missed call's only. PLEASE fix this issue.
    And kindly provide some camera improvements.
    I'm receiving loud notification sound while in call also
    Please provide timely Darkness for theme Instead of always being so.
    Wallpaper is missing gone full black most of the times
    Having quite malfunctioning issue also like Touch and delay process .
    Even community app notification isn't showing the highlighted notification after clicking for 2nd time only it's showing.
    thedeadfish59 likes this.
  14. Kenshi_blind_MDYH , via OnePlus 6T , Nov 5, 2019 :
    thanks I just did and it's better but still not quite like it was on pie. it's still fine though.
    thanks a lot
    T1570027087874 likes this.
  15. Rishabh_Pammi
    Eclair Nov 5, 2019
    Rishabh_Pammi , via OnePlus 6T , Nov 5, 2019 :
    I found the update not stable enough.. the phone got slow and buggy after the update. Also, many APKs which i use weren't functioning..
    Just switched back to 9.0 from 10..
    Here are some features i feel should've been there..
    The customisation should've had more options like, selecting apps which will turn dark when the dark theme is applied.. not all apps look good on dark mode..
    There should be an option to put a custom time for each theme..
    Like in Nova launcher how a dark theme gets applied depending on the time of the day..
    thedeadfish59 and iamkrafi like this.
  16. vidyanshuv
    Cupcake Nov 5, 2019
    vidyanshuv , via OnePlus 6T , Nov 5, 2019 :
    no VPN needed, simply download the oxygen os updater from Playstore and you can enjoy the latest build in no time.
  17. Sudhir_Samuel
    Sudhir_Samuel , via OnePlus 6 , Nov 5, 2019 :
    Raghu2706
    Do u find any issues or bugs? What is ur model?​
    My device is OP6.
    I find that sometimes the phone touch isnt responsive for few seconds.
    Network speed has been reduced.
    There Might be problem with installation of some apps.
    After i have installed it... I faced a terrible issue with google play store,
    Google pay, Twitter, phone pe, paytm.
    My browser mozilla Firefox couldnt load some of the pages (specifically when i tried to download apps from the other appstore line apk pure.. Even they didn't work.
    I cleared cache of the playstore removed the user account and again i logged in to the same. But not worked.
    CONNECT THE PLAYSTORE ON DEVICE WITH A STABLE WIFI CONNECTION. When once i done this my phone is back.... If such situation arises then do what i have said once, hopefully it should work perfectly.
    All d best [e]1f44d[/e][e]1f44d[/e][e]1f44d[/e].
    Raghu2706 likes this.
  18. johnhodge
    Cupcake Nov 5, 2019
  19. Raghu2706
    Raghu2706 , via OnePlus 6 , Nov 5, 2019 :
    ok. Thanks for the details buddy...
