1334
OxygenOS 10.0 for the OnePlus 6 and 6T
  1. Jegadeesh_kumar
    Cupcake Nov 7, 2019
    Jegadeesh_kumar , Nov 7, 2019 :
    Kenshi_blind_MDYH
    1. that is not a BUG (i swear some of you just use the word without knowing its meaning)
    2. again that is not a BUG, it is a design choice made by Google
    3. works fine here
    4. calibrate your screen using the advanced option and amoled wide colour gamut in the settings.
    5. again no context , the worst compared to what ?
    6. works 100% here
    7. when did you upgrade and how did you make the measurement to find the 5x times coefficient? after a new update , one must give time for the system to settle. i have been on android 10 for three days now and my battery life is better compared to what i had on android pie.
    8. not happening here .
    Again please do give context when you post stuff like​
  2. Chelikani234
    Froyo Nov 7, 2019
    Chelikani234 , via OnePlus 6T , Nov 7, 2019 :
    The reason why people choose OnePlus bcaz of price it's officer for hardware and software but anyway OnePlus gradually increasing the price with every new launch. OnePlus is the premium smartphone brand in India but i don't think so they will hold the position for so long bcaz if Google can reduce the price of their pixel mobile and if they going aggressive with their price imagine OnePlus sales how it will be! pixel mobiles get all the updates well before other mobile devices.. OnePlus can't hold the position by showing their oxygen OS for so long everything is matters here..
  3. Kenshi_blind_MDYH , via OnePlus 6T , Nov 7, 2019 :
    EthanMaskie
    I've been using Oxygen OS 10 on my OP6 from the 4th of November and while on the whole I think the update is good, battery life seems to have taken a massive hit. I've been leaving my phone at 72% before I sleep and waking up with 17%. Not quite pleasant since when I was using Oxygen OS 9, I'd sleep with a 100% and wake up with 90-92% (This is whilst sleeping with my phone on Airplane mode and all background apps cleared). I hope OnePlus fixes this issue at the earliest, because on the whole I think the battery life may have become alot worse than it's ever been on the OP6 in my experience. Thanks!
    if you used to get that high level battery drain while your phone was on airplane mode with all background apps cleared , I would suggest something is up with your phone, probably some apps and or processes that prevented the device to go into deep sleep mode cos it's not normal to go from 100% to 90%
    I'm on OOS10 and when I went to bed last night (it's 6:37 am in my location) my battery went from 100% to 97%, no airplane mode, WiFi on
    just for exemple This is my device battery usage since the last time I charged it ( i stream live TV,watch YouTube ,listen to music with Spotify and play a bit of real racing 5)
  4. G_vinodh_kumar_ONrp
    Cupcake Nov 7, 2019
    A.N.Hemanth likes this.
  5. Vatsal kamani
    Donut Nov 7, 2019
    Vatsal kamani , Nov 7, 2019 :
    my OnePlus 6t booted 6 times yesterday for no reason. first the screen would stuck and then there's black screen and I have to manually turn the device on. is there something I'm missing?
    Sahilkum likes this.
  6. manyou
    Froyo Nov 7, 2019
    manyou , Nov 7, 2019 :
    go to download Oxygen updater from Play store then you can get an update.
  7. sanketmaheshwari
    Cupcake Nov 7, 2019
    sanketmaheshwari , Nov 7, 2019 :
    Updated 2 days ago and having Battery Drainage issues already.
    Battery drains faster than ever, is this update really stable enough?
    asifansaringp likes this.
  8. as_if_i_am
    Gingerbread Nov 7, 2019
    as_if_i_am , via OnePlus 6T , Nov 7, 2019 :
    UI small issue . The color behind the bottom gesture bar should match the ui color or be transparent. But in some apps like pintrest, BHIM it's not looking nice. In settings it's black, in Google search it's white and that's wonderful. but for some apps it looks mismatch.
    Please look into this issue too.
    * phone is in dark mode
    * OP6T
    * OXYGEN UPDATER
    Sahilkum and K1571477336208 like this.
  9. as_if_i_am
    manyou likes this.
  10. as_if_i_am
    Swipe gesture via white bar from bottom does not work on home screen.
    I am on home screen and swipe left and right does not switch apps. This works in Pixel Android 10.
    Please look into this also.
    Ninja_Toru and K1571477336208 like this.
  11. L1571544740090
    Eclair Nov 7, 2019
    Teja1999 likes this.
  12. manyou
    Froyo Nov 7, 2019
    I've used the Q open beta for weeks and everything goes well except the Battery [e]1f609[/e]
  13. Mradul_Bhatt
    Froyo Nov 7, 2019
    Mradul_Bhatt , Nov 7, 2019 :
    yeah!!!
    totally agreed ...it's better to wait than to write the issues here.
    We believe that one plus will share the stable android 10 without any bugs which is more useful to us than to Android 9. And I know it will take some time.
    I personally believe that we don't have to make pressure on the devloping team to release the android 10 early coz sometime it will creat panic situations which will results in some serious bugs.
    All we have to do is just support the team so that they will creat a best os again for us.
    Go for it #oneplus.
    A-Josh87, Vikashlb and asifansaringp like this.
  14. nikhilj30
    Eclair Nov 7, 2019
    mahadevaswamys1999 likes this.
  15. adarshmondal07@g
    Donut Nov 7, 2019
  16. akuluki
    Donut Nov 7, 2019
  17. babinbubu
    babinbubu , via OnePlus 6 , Nov 7, 2019 :
    won't be necessary to show the list. you will realise ,when you get it in the last
  18. Z1538791355626
    Cupcake Nov 7, 2019
  19. S1566287166473
    Cupcake Nov 7, 2019
  20. utsav_prajapati_
    Cupcake Nov 7, 2019
