1334
OxygenOS 10.0 for the OnePlus 6 and 6T
  1. Y1545484669675
    Cupcake Nov 8, 2019
  2. emadfuad
    Cupcake Nov 8, 2019
  3. manyou
    Froyo Nov 8, 2019
    manyou , Nov 8, 2019 :
    don't need to do that, just use downgrade firmware to stable.
    Y1545484669675 likes this.
  4. Krishnamukesh
    Cupcake Nov 8, 2019
  5. Bittu Makhija1
    Cupcake Nov 8, 2019
  6. Z1529328346296
    Cupcake Nov 8, 2019
    Z1529328346296 , Nov 8, 2019 :
    we all are waiting for it only I don't OnePlus support is not working to provide the information to all users [e]1f620[/e]
  7. M1561659272733
    Cupcake Nov 8, 2019
  8. G_Ambu_SR_QDcD
    Eclair Nov 8, 2019
    G_Ambu_SR_QDcD , Nov 8, 2019 :
    i guess its space for bottom bar for quick switching between apps
  9. AK569
    Donut Nov 8, 2019
    AK569 , via OnePlus 6 , Nov 8, 2019 :
    is updating via OXYGEN UPDATER app safe? and even if i update my OP6 using oxygen updater, will i still be able to get those indian centric apps and features of OP6?
  10. vishalz
    Donut Nov 8, 2019
  11. VMMP
    Cupcake Nov 8, 2019
    VMMP , via OnePlus 6 , Nov 8, 2019 :
    Everything was going fine, since the update (2 days ago), but today, when I was not using the phone, I looked at it and it was stuck in the initial screen, the one that appear after a reboot (the one with the dots going around). I waited for 1 or 2 minutes, and then forced a reboot. It initialized normally.
    So it seems that there are some stability issues. Can anyone confirm that this is a common problem? Or is just mine?
  12. Y1545484669675
    Cupcake Nov 8, 2019
    Y1545484669675 , Nov 8, 2019 :
    ok thanks. is this theb right downgrade firmware?
  13. manyou
    Froyo Nov 8, 2019
    sorry I don't know where you downloaded your rollback firmware, but if you downloaded from my link, the file name should be like this...I don't know whether they are the same.
  14. Y1545484669675
    Cupcake Nov 8, 2019
    can you give me the link of your file sir? thank you
  15. manyou
    Froyo Nov 8, 2019
  16. Y1545484669675
    Cupcake Nov 8, 2019
  17. manyou
    Froyo Nov 8, 2019
    welcome, download the second file if you are using 6T.
  18. shantanunaresh
    Froyo Nov 8, 2019
