1051
OxygenOS 10.0 for the OnePlus 6 and 6T
  1. splinter_head
    Honeycomb Nov 8, 2019 at 5:32 PM
    splinter_head , Nov 8, 2019 at 5:32 PM :
    They have not stopped the update - it is out.
    If you want it sooner than the OTA, download an app called "Oxygen Updater" from the Play Store and use that to get the same Android 10 update
    Kytharsis and T1570027087874 like this.
  2. T1570027087874
    Cupcake Nov 8, 2019 at 5:33 PM
    splinter_head likes this.
  3. Miniterror
    Froyo Nov 8, 2019 at 5:36 PM
    Miniterror , via OnePlus 6 , Nov 8, 2019 at 5:36 PM :
    Hi,
    Not sure if i have a bug from Android 10 or from a application that i use but its getting quite annoying.
    I have a 1+6 and flashed the Android 10 image, afterwards i did a factory reset and started clean.
    All seems fine besides this one thing.
    With the slider on the right sideyou can set it to the profiles silent, vibration and ringtone.
    When i go to sleep i place it on silent, problem is that when i receive a notification like a whatsapp message, incoming mail or push message from a app my phone vibrates.
    As i often miss notifications during the day i have installed Glimpse to repeat notifications for 30 times every 30 seconds (unless i disgarded the notification).
    This results my phone vibrates 30 times at night every time i receive a notification.
    with Android 9 i used the same setup but did not have this problem that on silent mode my phone still vibrates, what else is the "vibrate" mode for on the slider.
    Do you guys have the same, phone vibrating on silent mode?
    Regards,
    L33t Pau likes this.
  4. munikumar99
    Cupcake Nov 8, 2019 at 5:41 PM
  5. Kytharsis
    Marshmallow Nov 8, 2019 at 5:42 PM
  6. munikumar99
    Cupcake Nov 8, 2019 at 5:42 PM
  7. Andreiaga
    Cupcake Nov 8, 2019 at 5:44 PM
    Andreiaga , Nov 8, 2019 at 5:44 PM :
    10.0 is a headache. Installed the update on my op6, and in some apps the phone freezes and enters a boot loop. I made a hard reset, installed 10.0 again and surprise the same thing.
  8. Sourav_jain8080
    Donut Nov 8, 2019 at 5:45 PM
  9. A7family
    Cupcake Nov 8, 2019 at 5:46 PM
  10. Kytharsis
    Marshmallow Nov 8, 2019 at 5:46 PM
  11. Kytharsis
    Kytharsis , Nov 8, 2019 at 5:46 PM :
    You only have to install it once then wipe your phone.
    ssanit and Auristic like this.
  12. Andreiaga
    Cupcake Nov 8, 2019 at 5:47 PM
  13. Kytharsis
    Marshmallow Nov 8, 2019 at 5:49 PM
    Kytharsis , Nov 8, 2019 at 5:49 PM :
    New Android version, expect apps to behave weirdly.
    Auristic and ironass like this.
  14. O1557067399719
    Cupcake Nov 8, 2019 at 5:54 PM
  15. ironass
    Lollipop Nov 8, 2019 at 5:55 PM
    ironass , Nov 8, 2019 at 5:55 PM :
    Lets not forget that in spite of 6+ months notice from Google, a lot of app developers on the Play Store have still not updated their apps for Android 10. I had to uninstall an app that I had used for a long time because it was not updated and causing all sorts of issues.
    Kytharsis likes this.
  16. Sinnaz0709
    Honeycomb Nov 8, 2019 at 5:57 PM
    Sinnaz0709 , via OnePlus 6 Silk White , Nov 8, 2019 at 5:57 PM :
    yup happened to me as well ... ensure that you use the feedback tool and share your logs so they can look at it in detail.
  17. Kytharsis
    Marshmallow Nov 8, 2019 at 5:57 PM
    Kytharsis , Nov 8, 2019 at 5:57 PM :
    ironass likes this.
  18. Shiva.V
    Eclair Nov 8, 2019 at 5:57 PM
    Shiva.V , Nov 8, 2019 at 5:57 PM :
    Things about New Android 10 update on my OnePlus 6
    I have not received this update through OTA. downloaded from OxigenUpdater.
    Qtn: Is it safe to update through Oxigen updater app?
    Ans: You can either cry for OTA, or update through Oxigen Updater. No one complained about malicious package being downloaded from that app(best of my knowledge).
    Pro's Observed by myself & my other community friends:
    • System wide Dark theme. I love dark theme as it saves juice in my OP6.
    • New Lock screen & Unlocking animations.
    • Customisation options for status bar icons
    • Good battery life compared to A.Pie.
    • Smart replies for text Messages & WhatsApp Messages.
    • Priority to manage all Apps permission.
    • Digital Wellbeing made is way to Oxigen 10.
    • Prioritising option for notifications.
    • New Calculator design.
    • Phone app designs & Video calling features got updated.
    • Oneplus launcher brought some more features like step counter, new way to open hidden space. Launcher layout.
    • Some negligible underthehood improvements.
    • Gboard isn't looking odd for me, its ok to have some space below the keyboard.
    Con's Observed in Oxygen OS 10:
    • Display looks bit dull, anyway now i set it to Advanced > Display P3
    • Googles gesture Navigation sucks. May be because i am addicted to Oneplus navigation gesture. Having difficulty in accessing hamburger menus by sliding from edges. Accidental Opening of Google assistant while navigating.
    • Sometimes shelf part wont scroll.
    • My iMobile app not logging in through fingerprint after update.
    • sometimes WhatsApp double ticks missing on opening screen (May be because i'm in Whatsapp beta)
    • Forced Dark mode option from Developer mode is messing with every UI aspect of the phone.
    • Phone app is bit slaggish while calling.
    • Download app is updated as Files. which is now every time set to recent files. Confuses between Googles file app, File manager.
    • No camera improvement.
    • Some UI bugs still exist.
    This update overweighs in features than the Bugs. I suggest to update through Oxygen Updater than the daily visiting this thread for checking OTA reception.:cool::innocent:
    Ge93 and U1528245230413 like this.
  19. Phanisai835
    Cupcake Nov 8, 2019 at 5:57 PM
  20. Kytharsis
    Marshmallow Nov 8, 2019 at 5:59 PM
    Kytharsis , Nov 8, 2019 at 5:59 PM :
    Thanks for letting us know. Please wait 3-10 business days for the next available update. Thank you for using OnePlus Community Forum.
    ironass and Auristic like this.
