1333
OxygenOS 10.0 for the OnePlus 6 and 6T
  1. _BlackPanther_
    Honeycomb Nov 2, 2019
    #61
  2. saurabhy90
    Cupcake Nov 2, 2019
    #62
  3. sandipan.nag
    Cupcake Nov 2, 2019
    sandipan.nag , Nov 2, 2019 :
    I have installed Android 10 Open Beta in my OP 6T. Will I receive any OTA update or I need to go back to Stable Android Pie to receive the OTA update?. Thanks
    #63
  4. Beejay23oneplus
    Eclair Nov 2, 2019
    #64
    S1534656837785 likes this.
  5. mischa1981
    Ice Cream Sandwich Nov 2, 2019
    mischa1981 , via OnePlus 6T , Nov 2, 2019 :
    I've got exactly the same Problem. try to Switch from "only wpa2" to "WPA/wpa2" in your Modem and then it should Work. seems to be a protocol Problem between Android 10 and some Modem manufacturors.
    #65
  6. Sascha_Srpak
    Cupcake Nov 2, 2019
    #66
  7. aa5hish
    Donut Nov 2, 2019
    aa5hish , via OnePlus 6T , Nov 2, 2019 :
    Yes, It is included :)
    #67
    S1570149012701 and Tommy.Gribe like this.
  8. MuertoKo
    Donut Nov 2, 2019
    MuertoKo , Nov 2, 2019 :
    Just inslaled from OnePlus Updater (wasn't showing as normal OTA). Everything running smooth, nothing lost, black theme as default for Google apps (calendar, search, chrome...) which is weird rid but nice. WiFi, data, faceunlock and all the usual stuff working properly with no relevant issue. Will try gestures in a few but everything else is perfect so far :)
    #68
  9. badulla.p
    Gingerbread Nov 2, 2019
    badulla.p , via OnePlus 6 , Nov 2, 2019 :
    Yes, you can root it
    #69
  10. ankkyankit11
    Froyo Nov 2, 2019
    #70
    pvskvr, SXXXlord and nirajbhusal like this.
  11. 7H3_F41C0N
    Froyo Nov 2, 2019
    #71
    SXXXlord likes this.
  12. badulla.p
    wipe cache and check it, it was same with beta as well but after clearing cache it disappeared
    #72
  13. Goku_SuperSaiyan
    #73
    Chosen_One and SXXXlord like this.
  14. #74
  15. C1560748479978
    Cupcake Nov 2, 2019
    #75
    E1552854644083 and SXXXlord like this.
  16. 18aniruddha
    #76
    SXXXlord and patlo like this.
  17. sivaraman.sony@g
    Eclair Nov 2, 2019
    sivaraman.sony@g , Nov 2, 2019 :
    how so u installed ?
    #77
  18. 18aniruddha
    #78
    Ramesh_Aluri and SXXXlord like this.
  19. cas8180
    cas8180 , via OnePlus 6T , Nov 2, 2019 :
    like it so far. BUT everything does feel noticeably slower. Apps take a little longer to load. Web pages take a little longer to render. It's marginal and I can live with it. But Android 9 was way faster all around.
    #79
  20. Beejay23oneplus
    Eclair Nov 2, 2019
    Beejay23oneplus , via OnePlus 6T , Nov 2, 2019 :
    Will give your suggestion a go thanks
    #80
    SXXXlord and AppuRibu like this.
