1333
OxygenOS 10.0 for the OnePlus 6 and 6T
  1. Rajashekar Punna
    Cupcake Nov 2, 2019
  2. Y1569153740975
    Cupcake Nov 2, 2019
  3. siva0531299
    Froyo Nov 2, 2019
    siva0531299 , via OnePlus 6 , Nov 2, 2019 :
    it won't get to older mobiles. It is exclusive for OnePlus 7pro and 7t pro bro
  4. lytoh38
    Gingerbread Nov 2, 2019
  5. siva0531299
    Froyo Nov 2, 2019
    not required through ota update
  6. Y1569153740975
    Cupcake Nov 2, 2019
  7. siva0531299
    Froyo Nov 2, 2019
    in next update they will provide features
  8. Nishath_1296
    Cupcake Nov 2, 2019
    Nishath_1296 , via OnePlus 6T , Nov 2, 2019 :
    Hello Team,
    I have updated my OnePlus 6T device to Android 10 using oxygen updater application, update has been successfully completed however I am not able to connect to my data connection since I installed it.
    Could you please review and advise what action should I need to take on it.
    Thank You
  9. Virendra2046
    Cupcake Nov 2, 2019
  10. harshu_mehta
    harshu_mehta , Nov 2, 2019 :
    I know but 6t and 7 user have not notification alert led so. If Oneplus give then much better.
  11. harshu_mehta
  12. KPlusUK
    Honeycomb Nov 2, 2019
    KPlusUK , via OnePlus 6T , Nov 2, 2019 :
    So far so brilliant. I find that the phone is smoother than before and animations are more smooth. Great update, no complaints from me.
    Sahilkum likes this.
  13. siva0531299
    Froyo Nov 2, 2019
    yes it is good but they told It is exclusively for 7pro and 7t oro
  14. farru1212
    Eclair Nov 2, 2019
  15. _BlackPanther_
    _BlackPanther_ , Nov 2, 2019 :
    no one will read/review here , read post #1 and report any issues , there is a process to report issues.
    Nishath_4042 likes this.
  16. siva0531299
    Froyo Nov 2, 2019
  17. Feelix93
    Donut Nov 2, 2019
    Feelix93 , Nov 2, 2019 :
    Anyone else having the problem that WiFi isn't woking after the Android 10 update?!
    It doesn't connect anymore?!
    There is also a grey bar under my Gboard - how to disable/hide that?
    Lockscreen is way brighter than homescreen too.
    cozzmat and Sahilkum like this.
  18. siva0531299
    Froyo Nov 2, 2019
    rakesh_sivva likes this.
  19. sharmanitin32
    Cupcake Nov 2, 2019
    sharmanitin32 , via OnePlus 6T , Nov 2, 2019 :
    No you don't need to all are intact the only thing is how you will update but for the safer side you can backup if you want to incase file might got corrupted during download
