1320
OxygenOS 10.0 for the OnePlus 6 and 6T
  1. pranjal18
    Gingerbread Nov 9, 2019
    pranjal18 , via OnePlus 6T , Nov 9, 2019 :
    Try wiping cache in recovery... Worked for me
    PDNR199502 likes this.
  2. PDNR199502
    Eclair Nov 9, 2019
    PDNR199502 , Nov 9, 2019 :
    can you walk me through? i didn't get it
  3. pranjal18
    Turn off your phone... Press volume down and power on button... It'll boot in recovery... Select language... Wipe option.. Select wipe cache
    Do NOT select wipe data... That is equivalent to formatting your phone
  4. PDNR199502
    Eclair Nov 9, 2019
    thank you very much!
    pranjal18 likes this.
  5. kmaier
    Honeycomb Nov 9, 2019
    Tr0uble78 likes this.
  6. PDNR199502
    Eclair Nov 9, 2019
    done! a little less laggy but i believe it will only improve with a correction update! thanks though
  7. pranjal18
    Yes yes... So my keyboard was quite laggy for the first few days... After that I wiped cache of the app and the phone.. And it now works well... I hope your device starts working well soon!
    Currently I am facing battery issues.. I'll drain it completely till 0 % and while its switched off.. Will charge to 100 %.... This will help the device recapture the battery strength.
  8. Deng bol
    Donut Nov 9, 2019
  9. P1552832341370
    Cupcake Nov 9, 2019
  10. rajeev1989abc
    Donut Nov 9, 2019
    19TCC62 and ratansuthar00 like this.
  11. kmaier
    L33t Pau, Matias Grebe and ramkr1607 like this.
  12. B1544123469038 likes this.
  13. amgtreo
    Donut Nov 9, 2019
    amgtreo , Nov 9, 2019 :
    Go ahead buddy, nobody will miss you!
    Tommy11, ArtuCer, L33t Pau and 5 others like this.
  14. bailamorena
    Cupcake Nov 9, 2019
    bailamorena , via OnePlus 6 , Nov 9, 2019 :
    I have update my op6 yesterday via oxygen updater. Everything works fine,except notification led when I have missing calls. And if the screen is on also,the notification led doesn't work for any app. :/
    AppuDas and ratansuthar00 like this.
  15. Feejus
    Froyo Nov 9, 2019
    Feejus , via OnePlus 6T , Nov 9, 2019 :
    Few thing I have noticed since using version 10 on 6T.
    1. Sluggish performance after 24 to 50 hours use. Notice animation etc run sluggish. A reboot will sort it out.
    2. After upgrade noticed Blue Tooth was connecting but no sound. Removing the BT and Re installing it worked fine.
  16. B1544123469038
    Donut Nov 9, 2019
    B1544123469038 , Nov 9, 2019 :
    The update is too bad.lots of lags in games or most of the times the games force close. Ignoring the gap under the keyboard though. But still disappointed with the gaming performance. Hope to get better gaming results in the next update.
    Lord Titi likes this.
  17. B1544123469038
    Donut Nov 9, 2019
    Yes there were some issues with the fingerprint and some other issues as well so.
  18. G_Luiz_Gabriel_Rudge_dzl
    Eclair Nov 9, 2019
    G_Luiz_Gabriel_Rudge_dzl , Nov 9, 2019 :
    today my phone, 1+ 6T just got the screen black and had to soft reboot him. anyone else had this? first time this happened to me on A10.
  19. OnePlusSQRT36
    Froyo Nov 9, 2019
    Ryu_Hayabusa_Listing likes this.
  20. Josiah1231
    Josiah1231 , via OnePlus 6T , Nov 9, 2019 :
    anyone have any issues with Android pay not working and not having Netflix show up in the play store? using a t mo convert running stable a10
