1333
OxygenOS 10.0 for the OnePlus 6 and 6T
  1. santihp
    Cupcake Nov 10, 2019
    santihp , Nov 10, 2019 :
    No, aún no. Esperemos que próximamente lo lancen a todos los OP6.
  2. |Solid_snake|
    Donut Nov 10, 2019
  3. mohammadfazil
  4. wamiq0509
  5. Kedarnath65
    Gingerbread Nov 10, 2019
  6. V1531592975746
  7. sachin_dabas
  8. Disarmoni
    Donut Nov 10, 2019
    Disarmoni , via OnePlus 6 , Nov 10, 2019 :
    OTA update for A10 on OP6 will be released when they see fit. If you want it now, use Oxygen Updater. You should know that there are likely hot fixes being applied to correct some of the issues people are having and that is likely why you haven't received it yet.
    If you use Oxygen Updater, you will likely have a few issues that haven't been hot fixed yet. Use at you own risk.
    Like others, I've had some of these issues. The only remaining issue I have is the 5ghz channel connection issue. Once it disconnects, it will not reconnect unless I restart the phone. This can be reproduced 100% of the time.
    I fixed Android Pay NFC payments by booting to recovery and wiping cache. (Unrooted)
    tr3b0r and U1528245230413 like this.
  9. Jayant2812
    Froyo Nov 10, 2019
    Teja1999 likes this.
  10. tr3b0r , via OnePlus 6T Midnight Black , Nov 10, 2019 :
  11. morimando
    morimando , Nov 10, 2019 :
    battery drained overnight because I didn't charge it. that's some serious drain
  12. AMYSMARTY
  13. jp4lm
    jp4lm , via OnePlus 6 , Nov 10, 2019 :
    That 5Ghz channel problem has been here since the OP6 came out and I have written about it several times. I think it's a hardware issue, and that can't be fixed with any software update as it seems.
  14. tr3b0r , via OnePlus 6T Midnight Black , Nov 10, 2019 :
    For sure you will get it, you just need to wait a little bit.
  15. Disarmoni
    Donut Nov 10, 2019
    Interesting... It's only been an issue for me since the A10 update. OnePlus has actually asked for my phone logs on this, so I'm getting ready to kick those over.
    Deactivated User likes this.
