1333
OxygenOS 10.0 for the OnePlus 6 and 6T
  1. Cervi
    Eclair Nov 2, 2019
    Cervi , Nov 2, 2019 :
    I knew that the version I had was not.compatible with A10, but I couldn't find one that did. It's not such a big deal, the other issues bother me more though.
  2. Cervi
    Eclair Nov 2, 2019
    Did you mean if it factory reset and clean install it ? No, it didn erase my phone
  3. Jaddu27
    Eclair Nov 2, 2019
    Jaddu27 , via OnePlus 6T , Nov 2, 2019 :
    aritra10
    already done restart but no change​
    In that case I would suggest you to report a bug in the feedback section this update contains many bugs and even I have started noticing a few of them.
    aritra10 likes this.
  4. aritra10 , via OnePlus 6T Mirror Black , Nov 2, 2019 :
    can you tell me where is exactly the feedback site. Actually i have never been there so need a little help.
  5. Jaddu27
    Eclair Nov 2, 2019
    on the main page of community app you would be able to see a plus sign in the bottom right corner click that in that you would have a feedback sign and in that kindly report the bug
  6. Cervi
    Eclair Nov 2, 2019
    I have noticed that as well. It happens to any keyboard. Gboard gets placed even higher !
  7. adelt
    Donut Nov 2, 2019
    adelt , Nov 2, 2019 :
    I have the same issue, using gboard, also there is an empty space on the home screen under the main apps shortcuts.
  8. Jaddu27
    Eclair Nov 2, 2019
    it is only the case menu using navigation gestures which are powered by Google.
  9. nochillyg
    Cupcake Nov 2, 2019
  10. Boubaker01
    Gingerbread Nov 2, 2019
  11. aritra10 , via OnePlus 6T Mirror Black , Nov 2, 2019 :
    done
  12. Artemus.
    Community Hero 2020 Nov 2, 2019
    Artemus. , Nov 2, 2019 :
    You might wanna factory reset to reduce the amount of carry-over bugs.
  13. suryagunturi
    Cupcake Nov 2, 2019
  14. Jaddu27
    Eclair Nov 2, 2019
  15. Boubaker01
  16. Jaddu27
    Eclair Nov 2, 2019
  17. HarryRag
    Honeycomb Nov 2, 2019
  18. Kruemelfelix
    Kruemelfelix , Nov 2, 2019 :
    use the latest GCam 7.1 beta 4 from arnova.
    Works flawlessly even with astrophotography mode.
    wdpangel4 likes this.
