1333
OxygenOS 10.0 for the OnePlus 6 and 6T
  1. .Yuvi.
    Eclair Nov 3, 2019
    .Yuvi. , via OnePlus 6T , Nov 3, 2019 :
    Hey buddy
    You'll have to go back to the stable version from the beta in order to get android 10 stable OTA. Remember that going back to stable pie will require you to lose all the data. Make sure you take a backup before doing anything.
    Have a great day [e]1f601[/e]
    Divyanshu_Sankhwar likes this.
  2. manojsingh646
    Donut Nov 3, 2019
    srikanth.s likes this.
  3. EswarPasari
    Donut Nov 3, 2019
  4. .Yuvi.
    Eclair Nov 3, 2019
    Actify
    So glad I stayed on pie totally worth it. Tha KS for beta testing for me guys!!​
    ikr, I'm glad that I didn't update too
    Gonna rock pie untill OP fixes all the issues
  5. jerm8832
    Cupcake Nov 3, 2019
    jerm8832 , via OnePlus 6T , Nov 3, 2019 :
    Well. The notification sound goes away when I set it to "other", but then I lose the weather notification from AccuWeather in the top status bar.
  6. .Yuvi.
    Eclair Nov 3, 2019
    You can install the update using the Oxygen Updater app from the playstore. But I highly suggest you stay on pie as oos10.0 has a lot of bugs and overall pie is very much faster too
  7. ironass
    Lollipop Nov 3, 2019
    ironass , Nov 3, 2019 :
    As the Android 10 stable is a later version than the Open Beta 1 release... you can either, download the FULL Android 10 stable ROM in Oxygen Updater and flash it or... just download the FULL ROM from one of the links in this thread and place it in your phone's root directory and flash it via Local Upgrade. A simple procedure for any competent Open Beta tester. :)
    drl431 likes this.
  8. .Yuvi.
    Eclair Nov 3, 2019
    Hey there buddy
    Gcam changes the image quality in a way that it's highly noticable. Gcam uses the full potential of your camera, you need to try it, you'll love it. Make sure to search for the correct versions as some include bugs..
    cahobs7 likes this.
  9. cahobs7
    Cupcake Nov 3, 2019
    cahobs7 , via OnePlus 6 , Nov 3, 2019 :
    Thank you for the reply! will definitely try gcam [e]1f44d[/e]
  10. abrajbhandari
    Donut Nov 3, 2019
  11. Maniviper
    Donut Nov 3, 2019
  12. M1566539048989
    Donut Nov 3, 2019
  13. Mannoni
    Donut Nov 3, 2019
    Mannoni , via OnePlus 6T , Nov 3, 2019 :
    I did not lose any data going from beta 1 to 10.0 via oxygen updater.
  14. docnok63
    Jelly Bean Nov 3, 2019
    docnok63 , Nov 3, 2019 :
    Having personal involvement, I HIGHLY suggest HyperCam R6!!! Based on GCam v6.2, there's both a Pie and A10 version!!! Unlike other GCams, I don't suggest any XML for this GCam with its new, built-in libs:
    http://bit.ly/36qi7qi
    cahobs7 and vovowong like this.
  15. AYYAPUSETTY JEEVAN KUMAR
    Gingerbread Nov 3, 2019
  16. T1572333222813
    Cupcake Nov 3, 2019
  17. Vivek237
    Cupcake Nov 3, 2019
    drkrishna likes this.
  18. Ashwinkumar989 , via OnePlus 6 Mirror Black , Nov 3, 2019 :
    Report this issue on oneplus bug reports forum
