1333
OxygenOS 10.0 for the OnePlus 6 and 6T
  1. P1535264021971
    Eclair Nov 22, 2019
  2. B_Wrath
    Nougat Nov 22, 2019
    ironass, Artemus. and joropamporo like this.
  3. joropamporo
    Gingerbread Nov 22, 2019
  4. joropamporo
  5. B_Wrath
    Nougat Nov 22, 2019
  6. joropamporo
  7. joropamporo
  8. B_Wrath
    Nougat Nov 22, 2019
    B_Wrath , Nov 22, 2019 :
    I'll help you out. Don't worry.
    Check if you have this setting enabled in the developer settings.
    buntycubal, ironass, drl431 and 2 others like this.
  9. joropamporo
    B_Wrath likes this.
  10. ToluBongz
    Honeycomb Nov 22, 2019
    ToluBongz , via OnePlus 6 , Nov 22, 2019 :
    Will consider this, thanks, but will wait till last day of November or my device is actually blocked (we are also warned to not use any unofficial or beta channels on our phones). I hope something comes soon. (Again I really don't care one way or the other about Android version).
  11. Trevor.Hawkes
    Ice Cream Sandwich Nov 22, 2019
    Trevor.Hawkes , Nov 22, 2019 :
    A large number of people are reporting that they do not have any problems with the update just as a large number of people are reporting that they do.
    The only difference is the device running the software.
    The main difference between devices is usage, settings, apps and conditions of operations.
    In other words the bugs, existing in the software, are kicked into life on some devices and not others.
    SO, unless you test the software on enough devices using enough different setups, apps and in enough different conditions you will not see all the bugs.
    It maybe that this version needed a lot more beta testing than it received.
    Should OnePlus have realised that. I don't know. Maybe they should.
    But they didn't.
    We assume the developers are working to sort it out.
    But, slagging off each other, OnePlus and the developers is not helping anyone.
  12. Danny_boy
    Danny_boy , Nov 22, 2019 :
    I am getting random reboots once daily from past 1 week.. android 10.0 oneplus 6t ... Pls do fix this one. Rest all is bearable
  13. G1558717087075
    Cupcake Nov 22, 2019
  14. sajileshkurup
    Froyo Nov 22, 2019
    G1569008375999 likes this.
  15. B_Wrath
    Nougat Nov 22, 2019
    I think you might have a accidentally turned on this. Turn it off and check.
    buntycubal likes this.
  16. Smxtren
  17. Artemus.
    Community Hero 2020 Nov 22, 2019
    Artemus. , Nov 22, 2019 :
    Instead of booing, why not read the cause? ;)
    Deactivated User likes this.
  18. N1541281596911
    N1541281596911 , via OnePlus 6T , Nov 22, 2019 :
    yeah just think, tht they r giving the updates to 7T & 7T pro users but nt to the 6 or 6T users !!
    ratansuthar00 likes this.
  19. Artemus.
    Actually, no. Each update gets its own timeline. We got ours, it got paused. The others didn't and are getting them on time. Please learn how software development works.
