1333
OxygenOS 10.0 for the OnePlus 6 and 6T
  1. Pratham01
    Cupcake Nov 24, 2019
  2. PapaMag
    Gingerbread Nov 24, 2019
    PapaMag , Nov 24, 2019 :
    I second this, clean install and Android 10 works fine without issues.
    Caomhin likes this.
  3. W1563675538936
    Donut Nov 24, 2019
    K_deep and darkwingz like this.
  4. satyalasumanth
  5. abhi613
  6. nishanth_k
    Honeycomb Nov 24, 2019
  7. Avaline
    Avaline , via OnePlus 6T , Nov 24, 2019 :
    if you bothered to read the post, you would see why the update isn't available yet. don't be lazy. am I right to assume you didn't read the weekly update either?
    Artemus. likes this.
  8. udaykn05
    udaykn05 , via OnePlus 6T , Nov 24, 2019 :
    @one plus have u forgotten A10 for 6 series???. R u guys still working on the bugs???. When can we see a stable version of A10 rollout for 6 and 6t series. U guys seems to be focusing on 7 series only??
  9. Nshstephan
  10. JAGADISH BHATTA
    Jelly Bean Nov 24, 2019
    JAGADISH BHATTA , Nov 24, 2019 :
    You need to adjust brightness with brightness slider to train you phone your brightness preferences
  11. kmaier
    kmaier , via OnePlus 6 , Nov 24, 2019 :
    as I have mentioned earlier, same with me on a 6 and I just cleared cache after coming straight from Beta on oxygen updater. really no issues.
  12. suraj1595
    suraj1595 , via OnePlus 6T , Nov 24, 2019 :
    no it has many bugs
    1.fingerprint animation is playing even after unlocking is finished
    2. gap below keyboard persists even after choosing OnePlus navigation gestures
    3. 2 file managers, 2 Google pay apps.. can't disable the extra file manager
    4. delayed touch sounds and keyboard sounds
    5. lockscreen cannot be changed from vibrant display calibration mode.
    6. wifi Direct is not working, certificates are missing
    7. no option to hide notch
    8. whatsapp notifications don't expand in quick reply mode
    9. the customisation settings change automatically
    10. the option to save both with and without Bokeh effect in portrait mode is removed
    11. the sound is too loud ( Max volume)while using earphones in calls and it doesn't change even if you change the volume
    12. no nightmode 2.0 even though Oneplus promised 2 years of software feature updates.
  13. P1512576257525
    Donut Nov 24, 2019
    suraj1595 likes this.
  14. PapaMag
    Not on my device, but I know people are having issues so just hang tight. I just know that if I am as disappointed as some are with OnePlus I would quit complaining and get a different device.
  15. suraj1595
    sure, 1 buggy build and I'll buy a new device. now why didn't i consider that option.
  16. JAGADISH BHATTA
    There is no always on display in oneplus phones
  17. S1549215256951
  18. PatrickNL
    AwesomeBoy likes this.
  19. F1558037797880
    F1558037797880 , Nov 24, 2019 :
    Oh sry, i mean the inactivity display? Normally i can See my own message, notifications and the time. Its all gone since the System Update. I can only see the Finger Scanner to u lock my screen.
  20. vlsimadhavan likes this.
