1328
OxygenOS 10.0 for the OnePlus 6 and 6T
  1. ManuAquino
    Cupcake Dec 3, 2019
    ManuAquino , Dec 3, 2019 :
    I already have the oxygen update 10, and it has already happened to me that several times my phone hangs up and I have to force it to restart it, does anyone else have that problem?
    masqu likes this.
  2. masqu
    Froyo Dec 3, 2019
    masqu , via OnePlus 6 , Dec 3, 2019 :
    Yes me and playstore bug
  3. AmanSaggu
    Cupcake Dec 3, 2019
    AmanSaggu , via OnePlus 6T , Dec 3, 2019 :
    anyone who has got the update. Can you please check the camera 2 api level on the new update. you may have to install an external app to check the level. { It is on level "full" in android 9 and the best possible is "level 3"}
    ManuAquino likes this.
  4. ManuAquino
    Cupcake Dec 3, 2019
    Is the same as before
  5. OPTRGT21
    Gingerbread Dec 3, 2019
    OPTRGT21 , via OnePlus 6T Midnight Black , Dec 3, 2019 :
    yeah the courier is in arabian sea....once the water restores it will sail through in your mobile....
    fma46 likes this.
  6. santiagoopintos
    Froyo Dec 3, 2019
    santiagoopintos , Dec 3, 2019 :
    The app "Camera2 API Probe" shows "Full"
    7508850990 likes this.
  7. AmanSaggu
    Cupcake Dec 3, 2019
  8. masqu
    Froyo Dec 3, 2019
    Ok my shot down after 10-30 sec
  9. OPTRGT21
    R1565744845711
    i haven't recieved 10.0 for 6t​
    yeah because 10 is bigger than 6, they are trying hard to cut short to required size....the tailor has gone for a leave without notice.....hr is taking new interviews....once all the mess is clean....OP will release
    shantanunaresh and ratansuthar00 like this.
  10. ratansuthar00 and Shay+ like this.
  11. AmanSaggu
    Cupcake Dec 3, 2019
    So they still aren't allowing us to use all the available hardware. Does enabling it through root and magisk help with apps like filmic pro though ?
  12. AmanSaggu
    Cupcake Dec 3, 2019
    So they still aren't allowing us to use all the hardware. Does enabling it through root help with apps like filmic pro ?
  13. Avaline
    Avaline , via OnePlus 6T , Dec 3, 2019 :
    spam helps no one and only causes annoyances
    Ellistar and Caomhin like this.
  14. OPTRGT21
  15. OPTRGT21
    ratansuthar00 likes this.
  16. Avaline
    because trying to make sure an update is big free and works well makes a company bad... I don't see your logic. sometimes things don't go as planned in software development. it's a fact of life. you really need to get over yourself if this is what you are choosing to get angry over.
  17. pavangn
    Donut Dec 3, 2019
  18. mdedhia
    Cupcake Dec 3, 2019
