1334
OxygenOS 10.0 for the OnePlus 6 and 6T
  1. DeepakSharma4195
    Cupcake Nov 3, 2019
  2. Vivek Unni
    Gingerbread Nov 3, 2019
  3. Darsh89
    Donut Nov 3, 2019
  4. kiran.benarjee
    Cupcake Nov 3, 2019
  5. kshgarg
    DurchEins likes this.
  6. Boubaker01
    Boubaker01 , via OnePlus 6 , Nov 3, 2019 :
    guys, there is something that i don't get it
    after downloading the rollback file (A9 STABLE)
    i went to system update and than the local upgrade
    and it says "move installation package to root directory"
    the question is: after downlaoding the file what should i do?
  7. Nirvanic
    Froyo Nov 3, 2019
    Nirvanic , Nov 3, 2019 :
    You need to move it download directory to Internal Storage.
  8. Bhavin. patel
    Eclair Nov 3, 2019
    Bhavin. patel , via OnePlus 6T , Nov 3, 2019 :
    move the download file to the internal storage and then try it
  9. MALU8484
    Eclair Nov 3, 2019
    MALU8484 , Nov 3, 2019 :
    I had the same problem... go back to touch id etc and press very fast the "more" botton, it should work
  10. Anth0o0
    Eclair Nov 3, 2019
  11. C1572728202454
    Cupcake Nov 3, 2019
    C1572728202454 , Nov 3, 2019 :
    Done it already. Thanks though.
    anilraj143j likes this.
  12. Boubaker01
    Saabmalik likes this.
  13. Bhavin. patel
    Eclair Nov 3, 2019
    try to hard reset the mobile ...i had the same problem but after hard reset the problem solve
  14. SUMEDH18
    Cupcake Nov 3, 2019
  15. Bhavin. patel
    Eclair Nov 3, 2019
  16. Bhavin. patel
    Eclair Nov 3, 2019
  17. splinter_head
    Ice Cream Sandwich Nov 3, 2019
    splinter_head , Nov 3, 2019 :
    danZerthinKers1
    when I will get OOs 10 update in my 6t​
    When the staged rollout hits your device. Probably sometime in the next few days
    danZerthinKers1 likes this.
  18. splinter_head
    If you're on 6T, you'll get it when the staged rollout hits your device. Probably sometime in the next week. If you're on a 6, then the update has been paused and we'll likely see it in a week or two
    MasterSkills29 likes this.
  19. R1530416269821
    Donut Nov 3, 2019
  20. Boubaker01
    i had to remove the file after discovoring that i can't do it [e]1f602[/e][e]1f614[/e], so im gonna download it again..
