1334
OxygenOS 10.0 for the OnePlus 6 and 6T
  1. harshal.joshi17
    Cupcake Dec 4, 2019
  2. ade0410
    Ice Cream Sandwich Dec 4, 2019
    ade0410 , Dec 4, 2019 :
    You have literally posted all these in about 8 minutes!!
    Stop spamming.
    What is your problem?
    Wait....like everyone else.
    B_Wrath and ironass like this.
  3. D1527142610170
    Gingerbread Dec 4, 2019
    D1527142610170 , via OnePlus 6 , Dec 4, 2019 :
    i am waiting bro what do you think i am doing
  4. Auxqii
    Honeycomb Dec 4, 2019
  5. C1539319470279 likes this.
  6. isushilksharma
    Eclair Dec 4, 2019
  7. snaveen07
    Cupcake Dec 4, 2019
  8. julez_
    Eclair Dec 4, 2019
  9. @Kanouted10s
    @Kanouted10s , via OnePlus 6T , Dec 4, 2019 :
    Surprise!
  10. J3FFR3Y
    Eclair Dec 4, 2019
  11. Darius_Jenkins
    Eclair Dec 4, 2019
  12. U1570439465555
    Froyo Dec 4, 2019
  13. Shridhar Devarangadi
    Cupcake Dec 4, 2019
    Shridhar Devarangadi , Dec 4, 2019 :
    Can some confirm that, is Beta 2 piece of code moved to stable channel? through oxygen updater app i have received piece software names OxygenOS 10.0.1 in stable channel. just wanted to check if it's beta 2 software moved to stable.
  14. viven2892
    Donut Dec 4, 2019
    cozzmat likes this.
  15. Last edited: Dec 4, 2019
    viven2892 likes this.
  16. kmaier
  17. arvinmradze
    arvinmradze , Dec 4, 2019 :
    New Stable Oxygen OS 10.0.1 4/12/2019
    Changelog
    System
    • Upgraded to Android 10
    • Brand new UI for Android Q
    • Updated Android security patch to 2019.10
    • Fixed the fingerprint identification issue
    • Fixed the animation lag for fingerprint unlock
    • Fixed the automatic reboot issue after upgrade
    Camera
    • Improved the performance and fixed known issues
    WiFi Connectivity
    • Fixed the 5Ghz WiFi connection
    Links
    OnePlus 6T
    https://otafsg1.h2os.com/patch/amaz...s6TOxygen_34_OTA_041_all_1911142208_af338.zip
    OnePlus 6
    https://otafsg1.h2os.com/patch/amaz..._22_OTA_041_all_1911142043_dde113e53cd0f9.zip
    Here comes the flooding same as the other threads.
    Q. When is the stable update?
    A. Wait... Don't ask for ETA's
    Q. I have issues in latest Open Beta etc.. etc..
    A. Clean install and check (don't dirty flashed you mess everything)
    Q. I didn't receive any updates? What I should do?
    A. Reboot and check in Oxygen Updater or do download manually the update zip.
    Q. Where's the download link?
    A. Above and it's New Stable Oxygen OS 4/12/2019
    Q. I have T- Mobile Version how can I update?
    A. " Messagefor T-Mobile converted units owners: trying to install this update will most likely lead to a hardware mismatch as it happened with OB18 and you will need to use MSM tool to recover your device (involves wiping your internal storage)"
    -but you can do it check XDA Thread
    Q. Can I downgrade to Pie?
    A. Yes. You can! Download the fulldowngrade zip and make sure you back up everything
  18. J1542976971074
    Eclair Dec 4, 2019
