1324
OxygenOS 10.0 for the OnePlus 6 and 6T
  1. Ramesh_r.gowda
    Cupcake Nov 3, 2019
  2. Kleb32
    Gingerbread Nov 3, 2019
    Coolguyy666 likes this.
  3. erua27
    Ice Cream Sandwich Nov 3, 2019
    erua27 , via OnePlus 6 , Nov 3, 2019 :
    guys did u want delete this space with the keyboard ? maybe we should do a survey and suggest oneplus to do something...
    VincentAbee likes this.
  4. cozzmat
    Honeycomb Nov 3, 2019
    Ninja_Toru likes this.
  5. Bhavin. patel
    Donut Nov 3, 2019
  6. damien2819
    Cupcake Nov 3, 2019
    damien2819 , Nov 3, 2019 :
    Hello ive a probleme, now since android 10. ive a white bar below my keyboard ? Any help? [​IMG]
    I was on Open beta, but now with official android 10. Its same, an idea ?
    kumindaniel likes this.
  7. vnodvaid
    Cupcake Nov 3, 2019
  8. JAGADISH BHATTA
    Jelly Bean Nov 3, 2019
    JAGADISH BHATTA , Nov 3, 2019 :
    OP6 update is on hold due to fingerprint scanner bug
    jhaakash01 likes this.
  9. erua27
  10. Nirvanic
    Froyo Nov 3, 2019
    Nirvanic , Nov 3, 2019 :
    Guys I Got OTA through Oxygen Updater.
    India 6t.
    Except for hiding Notch area there are no major bugs as reported by beta users.
    Pocket Mode works.
    Battery Drainage depends upon the Color mode you choose.
    Some apps were pre- loaded, so you may find two Gpay apps!!!
    No Apps have crashed for me.
    It's so fluent.
    Space under keyboard is to enable us use the gestures like back, recent and home.
    May be Google need to work on that space left below keyboard.
    My lock screen fingerprint is awesome, no issues.
    No network issues.
    All antennas working fine along with Wifi.
    Nothing much to complain so far for me....
    cheers OnePlus.
    You paid what's worth I have waited for.
    NEVER SETTLE.
    Marbona and Thitho007 like this.
  11. Ray_ofLight
  12. esridhar126
    Cupcake Nov 3, 2019
  13. Centurion888
    Cupcake Nov 3, 2019
    Centurion888 , via OnePlus 6T , Nov 3, 2019 :
    On my 6T I received the upgrade and it installed fine.
    Issues encountered so far:
    1) Nextcloud client no longer works.
    and a showstopper:
    2) All my ringtones were deleted. I mean the built in factory ringtones / notification sounds are GONE.
  14. Nirvanic
    Froyo Nov 3, 2019
  15. Nirvanic
    Froyo Nov 3, 2019
    None of my stuff was modified.
  16. vipulbariya2400
    Cupcake Nov 3, 2019
  17. P1572780038205
    Cupcake Nov 3, 2019
    P1572780038205 , via OnePlus 6T , Nov 3, 2019 :
    Hello, I updated the open beta 18 on my op6t and if I understood correctly, I can't install the stable version of android 10. I have a problem with screenshots that don't want to register with the beta. If someone had the same problem and managed to solve it, thank you for helping me if you could not explain how to reset it by having made a complete and lossless backup, thank you
  18. N1566288869244
    Cupcake Nov 3, 2019
  19. Prashant1113
    Cupcake Nov 3, 2019
