1333
OxygenOS 10.0 for the OnePlus 6 and 6T
  1. kmaier
    Honeycomb Dec 4, 2019
    kmaier , via OnePlus 6 , Dec 4, 2019 :
    strange because this is certainly newer THAN what you have. I am on a 6 so it's hard for me to say. I would say wait a day or two. seemS some 6t'S are getting it on OTA. GOOD LUCK. I still say Pie is fine.
    ododav likes this.
  2. Kedarnath65
    Gingerbread Dec 4, 2019
    Kedarnath65 , via OnePlus 6T , Dec 4, 2019 :
    yaa, it's there,guess what,I got a bug,i closed the settings app and opened it again,then there it is,after that i closed and opened the settings app again,its not there,and closed and opened settings again its there, it's happening alternatively Everytime.not only digital wellbeing but also google settings in the settings.
  3. AaaRrr
    Eclair Dec 4, 2019
    AaaRrr , via OnePlus 6T , Dec 4, 2019 :
    That's one strange bug.
  4. Dharmittt
    Froyo Dec 4, 2019
    Dharmittt , via OnePlus 6T , Dec 4, 2019 :
    is this not global stable version of Android 10 right?
    like OnePlus 7T has.
  5. Kedarnath65
  6. kmaier
    it's global stable for OnePlus 6 and 6t, which is different than the 7
  7. Dharmittt
    Froyo Dec 4, 2019
    so top of this forum
    suggest that u have to downgrade to pie to download stable version of A10, if u r in beta version.
    nd in oxygen updater there is suggation that u have factory reset ur device to download this stable version!
    I'm so confused [e]1f602[/e][e]1f602[/e][e]1f602[/e]😅😅😅
  8. kmaier
    shouldn't be. your beta is older than the new stable 10.1. you should be able to update straight without losing data.
  9. Dharmittt
    Froyo Dec 4, 2019
    should i downgrade my version as forum says or data factory reset as oxygen updater app says ?
  10. Kedarnath65
  11. kmaier
    and sorry, yes these things are made more difficult than they should be. it's not your fault.
    Dharmittt likes this.
  12. Vivek Unni
    Vivek Unni , via OnePlus 6T , Dec 4, 2019 :
    thanks everyone who waited for the latest update with patience instead of people who were just cringy to know where is the update. [e]1f60a[/e]
    PapaMag, _BlackPanther_ and Artemus. like this.
  13. kmaier
    will try to save everything. WhatsApp chats etc. factory reset isn't soooo painful. not sure why you need to do it, but that said, I recently did it. you could also wait. but if you are on Beta then you will one day have to change to stable. because if you are on Beta, you won't receive the full stable update. my advice it that if you aren't comfortable messing around with this, stick on the stable software. Pie, the previous software, is perfectly fine.
    Caoimhín likes this.
  14. hugocorreia78
  15. Kedarnath65
  16. ironass
    Lollipop Dec 4, 2019
    ironass , Dec 4, 2019 :
    BUMMER! :eek:
    Bad news for those on Open Beta 2
    The new official OxygenOS update, 10.0.1, has a build date of... 191114
    This is an earlier build date than Open Beta 2... 191120
    I have a feeling that this could cause issues for anyone wishing to switch from Open Beta 2 to OxygenOS 10.0.1
    Looks like it could be a full wipe job with either roll-back firmware or the MSMDownloadTool for the...
    OnePlus 6T MSMDownloadTool
    OnePlus 6 MSMDownloadTool
    Luckily, all our Open Beta testers are competent and experienced users. :rolleyes:
  17. B_Wrath
    Nougat Dec 4, 2019
    B_Wrath , Dec 4, 2019 :
    This below post is the reason. The beta will mostly be a newer build than the stable. Hence, going back to stable from beta will require you to use the rollback package, which in itself constitutes a data wipe.
  18. kmaier
    words of wisdom
  19. Kedarnath65
    yaa one is from OnePlus and one is of google,u see downloads app in Android 9, that's the new files app in Android 10,and file manager is from OnePlus.
  20. Kedarnath65 and Kazliux like this.
